IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5760 Views
  • 14 replies
Backstory - According to our carrier, we need SIP header diversions in our new CUBE router to allow for off-net call forwarding.  Basically map an internal extension number to a valid carrier supplied NANP number (they test calling party for security...
mlpalmer by Level 1
  • 270 Views
  • 2 replies
Resolved! SIP Trunk SRST
At our company we are doing SIP Trunking between the provider and CUCM.  The trunk terminates on the call manager itself.  We don't have any CUBE in our environment.  Most of our remote locations have a regular router with no pvdm, fxo, or uck9 and c...
ty.masse by Level 1
  • 1632 Views
  • 5 replies
hello all, we have two cluster , each cluster should have 5 phone  and cluster is seprated from each one. requirment is to ring each 5  phones at the same time in both he cluster when we call a toll free number in one locaiton. how to proceed with ...
HI everybody, I found a VG224 on my warehouse and I need to use it for a client, but I dont have the patch panel, nor the cable that joins VG224 to this patch panel.  Can anybody  tell me what are the references of those items? Thanks
Hello all, From BE6000 link, http://www.cisco.com/c/en/us/products/unified-communications/business-edition-6000/index.html BE6000H Model: Cisco Unified Communications on Cisco UCS C220 M4 Rack Server supports up to 1000 users, 2500 devices. What is d...
 I purchased cisco Business Edition 6000 10.0 as the following: BE6K-START-UWL25    BE 6000 - User License Starter Bundle with 25 UWL Licenses                1 BE6K-UWL-STD           Cisco Business Edition 6000 - Workspace License Standard          ...
Halsser by Level 1
  • 3189 Views
  • 14 replies
Hi, I'm aware that conference call internally only works with G.711. Since we have two sites that uses different device pool in which the Region configured to used the is G.729 codec and the conference call is not working unless a transcoder is conf...
