All,when trying to log into the AC admin page the user name is showing up in all caps even thought I don't have caps lock set. If I try it with caps locks it still gets typed as all caps. I think the same thing is happening with ...
Any ideas or links to setting up a basic Personal Assistant in CUCM 10. I think I have done this with second lines and secndary calling search spaces. Anyone help?
Dear All, I am using CME in our network and we are facing very strange issue. When i dialed the number by using "off-hook" then Cisco Iphone is not sending the complete dialed digit to CME. Whereas when i use "on-hook" way to dial the digit then C...
Globalized the dial plan, but when the call goes out the PRI I lose the + when the call goes out the PRI. I know the + is not supported on PRI, but I'm trying to figure how to stop the updating of the caller ID when the call leaves CUCM. I've had t...
Hi, Does anyone know how I change the expansion module mode from 2 columns to 1 column on an 8800 expansion module? Ciscos documentation on the configuration is poor / non-existant Thanks in advance
I have 7941 ephones and I need to move and give them a different room number, so I changed the name of the phones on the server and saved it, but when I called my phone extension the old name still shows appears as who called, but when I look at phon...
Hi All, I am in the process of installing cmterm-devicepack8.6.2.26169-1.cop.sgn on our CISCO Business Edition 3000 8.6.4.10000-15 in order to add support to 7821 phones. But during the installation I get the following error. I have already instal...
This should be simple, but I just want to be sure I have it correct before doing this. In this example (for the USA), CUCM will not send the leading 9 to the router/gateway. 9-1-858-555-1212 dialed by the user would result in 1-858-555-1212 being s...
Hello All, We have dual 3845 ISR Cube Routers in our Data center currently configured for 250 ccps. We are adding offices and will have to add another 100 ccps to our router. Does anyone here on the forum know what if any limitation there is in re...
Dear All, I need to order license for 7945 phone and my client says with smartnet, kindly help me understand this. find the below info and confirm whether this one is the correct license for 7945. CUCM version : 8.5.1 What does he mean with sma...
just looking for some help with configuring Bogen PCM-2000 to Cisco Call Manager. Currently, we have a branch site running CME with Cisco 2851 router. It is using FXO port to provide the paging functionality to the users. Of Course, it has dial-peer...
Hi , we have a requirement where the agent would initiate consult call to pstn. When dialing the number sent to the pstn would be the number of calling party instead of agent phone. Is that achievable via CUCM or via any header changes using SIP pro...
Is there any configuration option for the Cisco phones, that would allow to schedule the 802.1x reauthentications at specified time on daily/weekly basis?
Hello, I am using CUCM 9.1.2 . Call park feature does not work only in 1 branch . It configured the same as every other branch . It configured to specific number . Any idea ?
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
| User | Count |
| 5 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
