I was trying to block thru CUCM but no luck, kindly help if it is possible
I have a strange issue that I have nailed down to one area of a customer's footprint for their UC infrastructure. Basically, they get one-way audio on only a select few phones while others on the same VLAN and PRI do not exhibit these issues. It's ...
Dears, how to check the installed DSP module on router, and for 150 users which DSP module should be use. thankx
Hi Experts, I'm new in Cisco world, as an IT who look after our IT affairs, also I've been asked to manage our company's IP Phone, which i stumbled upon, I'm using Cisco Configuration Professional and Cisco router 2900, at first i thought i am goin...
Hi Looking for version 9.1.2.10000-10 iso (Unity connection). Anyone? :)
Hi teamI have below setup9971 A (DN:4002)----SIP CME(10.68.233.72) -----CUBE(10.68.233.71) ------ CUCM (10.68.233.35) ----- 9971 B (DN:2220)both CUBE and SIP CME will terminate Signaling and Media.when 4002 call 2220, and 2220 pickup the call, CUBE w...
Community peeps, Just throwing this out there to see if any of you have come across this as well. Updated Chrome the other day to version 47.0.2526 and now it seems the drop down menus in Call Manager ar no longer working. any one has a work ...
Dears, In our network we are facing problem, can not receive any incomming international call what I do.can any tell me about translation rule for incomming dial peer like 13 digit to 4 digit
Dear all, I am facing following issue: Cisco 7942-G IP phone is not registering on 2951 router, "max-ephone rejected" is displayed on the phone screen. Solution applied by me: I removed the telephony service and again enabled it by increasing the...
Hi,We are running a CUCM 8 cluster and have a cisco 2811 that is taking care of sip trunk connectivity for PSTN access.The 2811 is also our MTP,CFB and Xcoder.Whenever we put an inbound or outbound PSTN call on hold, there is silence. Internal calls ...
1. Does anyone have a port configuration example for a 3850 which includes all the QoS commands for a working phone that has a PC hanging off it? 2. Does anyone have a configuration for a trunk port between two 3850 switches that trusts the DSCP and ...
Dear All, I just started to work in Cisco Call manager. currently the problem i am facing that whenever i dial any number from my cisco ip phone then its striping 1 digit somehow. I checked the running configuration and i have doubt if the below c...
Hi ; I want to enable PKI to in 7940 operating with Elastix to make connection secure , is there any other for doing this , . Can any body help step by step . Shall be thankful for help Irfan
Hi all, I configured the GUI in CallManger Express for SCCP phones it's ok, but for SIP Phones don't appear in GUI. where is the problem, SIP Phones aren't supported by the GUI? thanks in advance, Regards, Moussa
Hi Everyone, We are upgrading from 8.6 to 10.5 The objective is to Mirror the production servers in the lab with new hardwares in an isolated network and then switch off the production servers and switch on the ones built in the lab within a mainte...
| Subject | Author | Posted |
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM | ||
| 03-16-2025 03:42 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
