Dear all I have faced an issue with Cisco ATA 187; the incoming calls are not working, but the outgoing calls are working.I tried to reset it, but nothing changed.Can you please support me on how I can fix it?
How can I ensure support for 6000 users with the BE7000H? Also, how many "VMW-VSP-STD-3A=" licenses will I need? According to the BE7000H data sheet, it indicates support for up to 5000 users only. However, I came across information from "https://www...
Folks, I have these part numbers L-CUBE and CUBE14-T-STD on the smart account, Are these part numbers for a perpetual license of CUBE? if it reaches to the end contract, the service will still be running?
Hello,I am attempting to set up a Cisco 7841 IP Phone with SIP. Unfortunately, I am getting an error with the SEP[MAC].cnf.xml file. The phone's status messages show "Error Verifying Config Info". I tried making one myself, but it simply isn't workin...
Hello,I ran into an issue with ATT PRI and hope someone can shed some light.We have a ATT PRI connected to a Avaya PBX and we are going to migrate the legacy system to our centralized CM cluster. I configred a Cisco 2951 ISR router running MGCP. I ...
Can someone please explain what do you get with just the UCK9 license ? UCK9 : AdvUCSuiteK9: uck9, cme-srst, cube Currently I have a 4331 (IOS XE 16.09.04, not on smart license) that I am using for data and want to use it as a CUBE, do not need CME ...
Hello all,I have problem with Cisco IP Communicator 8.6.3.0 I changed my laptop and I changed the mac address on Communicator but it didn't work and I got message on the display "Configuring IP"Please support
I am unable to connect the routers to the internet. I have the cisco Ip phones 7945s and the 7841s. I have the firmware needed for the phones on my pacstar 447 routers, I have each type of phone in its own folder in my voip folder on the router. I h...
Dear AllI have Cisco CP 3905 phone in our office. I just want to know that it support 3pcc Firmware or not ?Please confirm. I want to register this phone with another vendor IPPBX .Is it possible or not ?
I have Cisco Unity 11.5 configured via sip to a CUCM v14. I have configured voicemail and everything works as expected except for one thing, when users press voicemail on their phone there is a long pause (10 seconds) before Unity will start playing ...
My Finesse profile doesn't have a phone directory - my co worker and CCX customers do. I was able to add/delete contacts for their group directories, I know now that the changes didn't take effect until they log off/on again.I tried various CCX setti...
Hi guys, I have a trouble with my CME, with FOX card, I've configured custome-cptone on voice-port FXO, but when I disconect call from PSTN, the call is not disconnected in my softphone.PSTN --------------------- CME ------------------------- (plar) ...
After Agent answers an ACD call, attempts a Direct Transfer to an invalid extension.Finesse produces the following error and takes about 10 seconds to return back to the active call. UCCE 12.5.1.10000-24 ES08 Error: Cannot Perform Operation. ...
I have a JTAPI application that needs to record the called party's DID numbers for the Incoming Calls. Incoming Calls to 11 digit DID over SIP trunk get directed to an internal 4 digit DN on a CTI Routepoint via Translation pattern with Called Party ...
Hello, We are having an issue with only certain numbers. The number is dialed then you hear maybe half a ring then silence. The calls stays connected but no audio and I see sender packets going out but no receiver packets. the calls flow is as fol...
| Subject | Author | Posted |
| 03-09-2026 11:06 AM | ||
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM |
