IP Telephony and Phones
Labels
Hello All,Need your help.Call Scenario:Cisco IP Phone --> CUCM --> SIP TRUNK --> Free switchWhen I am making an outbound call from my Cisco phone which is registered with CUCM to a Free switch which is configured as SIP trunk,I am getting 488 not acc...
S N by Level 1
  • 1225 Views
  • 4 replies
Hi, Looking for some help with running an SQL command to count the number of trunks. This will return the count of most of the trunks: run sql select count(tm.name) as Total from device as d inner join typemodel as tm on d.tkmodel = tm.enum where tm....
Hi, CUCM version is 9.1.2 Voice gateway 2951 with IOS 15.2(4)M4 There is a SIP trunk between voice gateway and SIP provider.There is a SIP trunk between  voice gateway and CUCM. Outgoing / Incoming calls to/from  PSTN via SIP trunk are completed Ok. ...
Hi Guys, I got issue in my CUCM in outgoing calls. I created new DNs & can’t make outgoing calls (incoming is Ok). This is the gateway connectivity SIP---CUBE-SIP Trunk to CUCM Old DNs are working fine & no issue. New DNs are exactly the same. We exc...
Suchi by Level 1
  • 478 Views
  • 3 replies
We are having a real strange issue with our 4331 gateways when testing SRST.  Information 4331 Configured in CallManager via SIP 4331 has an Inbound PRI Config Snipit dial-peer voice 1000 voip preference 1 destination-pattern 51754[13]....$ session...
mzajeski by Level 1
  • 1824 Views
  • 13 replies
Resolved! DID to extension
How does CUCM map incoming 10 digit calls from PSTN to the 5 digit extensions in CUCM? I have searched but cannot find how my Call Manager does this. There are no transformation patterns or translation patterns in CUCM or configuration on my MGCP gat...
Issues A user is having problems where when people call him, sometimes he receives busy signals, but his phone rings, he picks up and there is silence.The same user said that at certain specific times of the day he has been getting busy signals. Sc...
