add CUWL STD Licence for CUCM 9.X
how can I order additional CUWL standard License for existing CUCM 9.X ?
Dear,Does Cisco Collaboration provide multi tenancy, mean if we implement in cisco Partner's NOC to monitor different customer IPT. Along with this can we give each customer user veiw access for his own instance.
HiWe are wondering if exist a workaround for BootUP Automatic MCS servers when we have a power failureIs possible to boot auto these servers?Regardscc
hello , i am working with a secure ip phone enviroment that use CTL files and im looking to implement VPN phones for teleworker users , what is the best practice secure configuration i need to implement it . i have asa 5512x firewall and i have the c...
Hello! I have a UC500 box that is hosting multiple IP phones on the same LAN. Configuring codecs for outgoing IP calls had never been a problem as I had to do it in IP dial-peers. Problem:One of our guys who works from home has requested that I giv...
Hello all!I've been trying to find a way to tie outbound calls from a particular IP phone to a particular FXO port, essentially creating a DiD situation for the IP phone on an analog CME system. I know you can point the inbound calls that come into...
Hi,We trying to integrate Fenestrae Fax server with Cisco 2951 voice gateway. Call Sequence is like that. Fax Srv >>> sip>>>Cisco2951VGW>PRI interface> outside fax number> We did some config but unfortunately fax sending is disconnecting after couple...
Hello,My eyes are crossed from reading so many docs on QOS. I have a Cisco 2811 running CME, 10x1 connection to the Internet, SIP trunks to Callcentric running g729r8 and g711ulaw. Phones are 7960's running SCCP. Runs well except when someone is d...
Hi,I have made home Lab using GNS3, CUCM and SIP-UA.com to simulate sip call. I am able to dial out and call also get connected but dropped after 10 seconds. Logs shows normal call clearing. Anyone please help resolving this issue.Thanks!!
Hi Everyone,We just upgraded our CUCMs from version 8.6 to 9.1. The upgrade was successful but it looks like we lost some datas (User, Phones, Profiles, etc...). There was a week of dely btw the software installation in the inactive partition and the...
Hi,While connecting Cisco 7800 Series Phone on the Brocade Switches, this particular model phone not getting the IP Address from the DHCP and i have tried to given static IP address as well but its not reachable. But when i connect the other all mode...
Hi All I would like to provide some SRST fallback for a few phones that are used in IP Contact centre express. The voice gateway will have either a series of analog lines in a Telstra hunt group or a partial PRI service. I think that I can use the al...
What type of database & which version is used in CUCM - System version:9.1.1.20000-5. CCX – System Version:9.0.2.10000-71 Thanks & Regards,M.Mohamed Raffiudeen...
HiWe are planning to upgrade CUCM, IM, CUC from version 9.1.2 to 10.5Question is,Once I complete the upgradation of CUCM,IM, CUC. Do I need to do any upgrade on ELM separately?Or while upgrading CUCM from 9.1.2 to 10.5, ELM will also be automatically...
I have a customer who has many CME’s in the field and over the years have been using 79XX phones with SCCP. Now they are being pushed to 88XX phones using fastrack. I have been researching this and it looks to me lime 88XX phones are not fully suppor...
Subject | Author | Posted |
02-06-2023 02:33 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM |
User | Count |
10 | |
5 | |
4 | |
4 | |
2 |
