Is it possible to list all the extensions in one place on a VG224 from Call Manager (8.6).?I find various methods to list the ports but no extension /DN details. No Dependency record option from the Main VG224 page.
We are currently using Calabrio's Workforce Management, Cisco did all the installation for us. The newest version (CalabrioOne 9.4) is out now, what I was told on another forum is to open a case to get assistance to upgrade to it, would we do that w...
I am facing an issue wehre i am trying to deploy globalized dialing ie + dialing for outbound and inbound and dont know how to deal with large no of local area numbes with requires 11 digit dialing (1 and 10 digit).SO i am in NPA area where some num...
I have calling party transformation setup, and working correctly when a phone has a DID associated to it. Unfortunately if a caller goes to a call handler, then dials the users extension it no longer works.Working: Dial 555-1212 (DID) --> Rings...
Is there a built-in method to make the CUBE report call quality statistics over the SIP Trunk connected to the CUCM CMR?I have a CUBE on 2921 v15.4(2)T1 and tried to follow the CUBE Configuration Guide on configuring it for call quality reporting (ht...
I'm testing the app imagicle which contains CDR capabilites I'm trying to set de FTP path for the cdr records but it contains spaces: The FTP path is :C:\Program Files (x86)\StonevoiceAS\Apps\BillyBlues\Engine\ccm_express\1 When I try to configure it...
Dear Team, I have installed CUPS 10.0 in cluster mode but I am facing one issue that my XCP directory service is not starting. Best Regard Irfan
Trying to get an 8811 phone working using fast track on a CME 10.0. Does anyone know the proper reference-pooltype to put for and 8811 or for all the 88xx phones? Seems there would be a document somewhere but I can't seem to find it.
Hi AllVoice Gateway is configured as mgcp .Issue is voicemail is not working in case on fallback. Pls see the below configuration :I have CUCM 10.5 and Unity connection 10.5. Attached are the Unity snapshoots !no aaa new-modelclock timezone GMT 4 0n...
Hi, I am trying to configure spanish language for 79745 & 7975 IP phones.I'm not allowed with my Cisco Account login to download the locale configuration files.Can somebody some free site to download locale configuration files?I need the td-sip.jar f...
Hi all:I would much appreciate if some one walk me through the steps to have Unity Connection voice mail in SRST mode.I am not able to make it work the unity connection in SRST, however I made partially to work with VM-Integartion commandPlease if yo...
Dear All, There is a Cisco 2911 and ISDN BRI service in the test lab, and we would like to integrate the ISDN service on the Cisco 2911 router.Should we purchse the 1-port isdn bri wan interface card or 1-port analog modem interface card? Please shar...
Hi All, Please provide me below information: 1) Why CUCM gives error when adding 4th nodes into the Cluster? But there are 9 nodes(1 Publisher and 8 Subscibers) How come? Please tell me clustering with associated of all nodes. thank you
Hi everyoneOur network guys recently setup some new NTP servers that require authentication. I know you can configured the following on a router/switch to allow for this, but is there a way to configure this for CUCM? I'm running 8.6 ntp authenticat...
Is it possible to forward calls that I take (as an admin assistant) DIRECTLY in to my boss' voicemail?? New to this phone system, so it may be simple but I can't figure it out! Thanks!
Subject | Author | Posted |
03-27-2025 12:55 PM | ||
03-27-2025 10:13 AM | ||
03-26-2025 12:17 PM | ||
03-21-2025 01:42 PM | ||
03-20-2025 05:12 AM |
User | Count |
4 | |
1 | |
1 | |
1 | |
1 |
