IP Telephony and Phones
Labels
Resolved! ATA190 + CUCM 10.5
All,I am trying to get an ATA190 to register with a 10.5 cluster. Unfortunately I don't have the firmware available in Device Defaults within UCM.What is the process I need to follow to enable this device to work in my cluster?Also how do I obtain th...
drbabbers by Level 3
  • 495 Views
  • 2 replies
Hello. There are a couple of lines 1760 and fxo. By 1760 2 sccp connected device and one sip. With sccp all right, but do not go to sip incoming calls. Please tell me what could be the problem? version 12.4 service timestamps debug datetime msec serv...
At work we have SPA508G IP phones and i need to use a PC headset that is provided, As there has been no previous checks for compatibility i am now having to look for a fix, do dual 3.5 mm jack females to 2.5 mm jack male work as an adapter? Buying ne...
My Customer is running on CUC  8.6.2.24089-2. As a part of a bug fix I have suggested them for an upgrade to an ES.I want to understand the risks of upgrading to an ES and why is an ES release always avoided for upgrade recommendation?.there seems to...
maeswara by Cisco Employee
  • 684 Views
  • 5 replies
Got an interesting requirement from my customer. They are going to install 8 T1 PRIs on two gateways. 4 PRIs will provide 92 B-channels on each gateway. The Telco will distribute the DIDs across PRIs to load balance the inbound calls and the Route gr...
hi guys!I need information about a CDR.I  need a report of unanswered calls, and tickets are sent to my FTP these  tickets does not have information on unanswered calls.Will I need to enable some feature.I am using CUCM 7.1.3
We are currently running CUCM 7.0 and CER 7.0.  We want to stop CER from intercepting any 911 calls, temporarily.  What is the best way to do this?  Also, if this is done, do the 911 calls get routed using the route list in the 911 route pattern?
dtom by Level 1
  • 284 Views
  • 2 replies
Unanswered Topics
