IP Telephony and Phones
Labels
HELP IN Mediasense upgrade
Dears,I'm About to upgrade our Mediasense server from 9.X to 10.XI need your help guys in this like the Refresh Upgrade COP file how can i get it also is it the same sequence as upgrading Normal CUCM Also Can i rollback if anything happened THanks gu...
ISDN PRI not coming up
Hi All, We are turning up a LD PRI in a site ..but even after turning up the D channel it is not coming up. The switch type is primary ni2.Below is the current statusISDN Serial0/2/0:23 interface        dsl 2, interface ISDN Switchtype = primary-ni  ...
shyam2014 by Beginner
  • 566 Views
  • 5 replies
Is using POE cheaper than using a power cube for ip phones (consumption)
Good day, I have a question regarding the use of a POE switch.At this moment we have around 200 IP phones.All these phones use a power cube connected to the electricity.Our switches are not POE so I want to replace them by POE. My question is, is usi...
Connecting Cisco 7906 to asterisk
Hi I have cisco cucm ,There are cisco phones (7906) i just want  to try with asterisk server . so i created two vlans , one for endpoints other for asterisk server . What is the best practice running cucm and other pbx in an enterprise network . Do i...
susim by Participant
  • 484 Views
  • 8 replies
