IP Telephony and Phones
watch here Journey banner_1
Labels
Hi, I'm trying to configure fac but it doesn't work. See my configuration below: voice register pool  120 pin 1234 lpcor type local lpcor incoming TRUNK busy-trigger-per-button 2 id mac E0D1.73E4.2AFD type 7841 number 1 dn 120 cor incoming local-outs...
Hello,We are using a 2811 Router for CME, and i have this DSP Warning DSPs1,  in slot 0 are using non-default firmware from flash:This is not recommended, the default version is 23.8.1 IOS:c2800nm-adventerprisek9_ivs-mz.124-22.YB8.biInbound calls are...
Hi, Can Cisco CME to act as the DSP farm host for MTP resource?I know it's OK for transcode and conference resource. But It's not successful with MTP resource.===============SiteB#sh sccpSCCP Admin State: UPGateway IP Address: 10.30.41.1, Port Number...
kevintang by Level 1
  • 1945 Views
  • 6 replies
Hi, The record-route is missing on ACK after re-invite challenges, and per RFC my sbc is dropping the call. I have detected this on all cisco spa's 500 series including the ata 232D.  Firmware tested: SPA 500 series: 7.5.6a & 7.5.7(s) fw  SPA 232D: 1...
robbstark by Level 1
  • 2716 Views
  • 5 replies
Hi all,I want to backup everything that is on a flash card of our VOIP PBX. So far found that copy flash: tftp: I need to specify filename that I want to be copied. Can I somehow copy entire flash card?Also if I want to save my configuration, I need ...
Hey,Am using a cucm 8.5 and i have deployed different sets of phonesthey are working correctly, ringing instantly when you initiate a call to another phone But when i initiate a call or transfer from  the DX650 phones to another phone like 7875 or 79...
divine007 by Level 1
  • 440 Views
  • 1 replies
