IP Telephony and Phones
Personalize banner_3
Labels
We have an Active CUBE with 3 PRI links connected and a Standby CUBE with HSRP running. The question I have is if the Active CUBE fails, is there any way to have a setup that doesn't force a user to manually swap the PRI links over to the standby CUB...
joshbradley by Community Member
  • 353 Views
  • 2 replies
Hello All, I will be grateful if someone can help. I am trying to get X-Lite (version 4.8.4) working with our CME. The phone successfully registers with the CME and I can make the calls out from the phone. But when I try to make a call to the phone I...
Jamal Ahmed by Community Member
  • 1777 Views
  • 4 replies
Hi I would like to change the number of number of rings before the IP phones divert to voice mail. Currently the phone is on a hunt group but due to staff holidays we are running with 1 staff member. We are on version 9.1. Any advise is appreciated.T...
All,I have a series of Cisco 7821 handsets that at random times of the day will show 'Phone Not Registered', 'Resetting' and then 'Registered'.I can't see any obvious network issue between the phone and it's Active subscriber.Any ideas how I can prog...
drbabbers by Level 6
  • 1054 Views
  • 5 replies
HiI have Ip phone, connectivity as follows IP Phone-- CUCM ---CUCM has PRI-QSIG with EPABX -- ROUTER IS registered as MGCP Gateway the Location analog phone and Ip phone have same series numbers e.g. 3001 (analog) 3002(IP Phone) But when i call via I...
