IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1165 Views
  • 6 replies
Resolved! local VoIP - LAN
Hello..I have a local network that consists of a Router, a Fire-Wall, a core switch (4507R) and Several (3750) switches which are connecting more than 100 end-point PCs.I need to implement local VoIP between devices (either software on PC -Preferred-...
Dears,I'm About to upgrade our Mediasense server from 9.X to 10.XI need your help guys in this like the Refresh Upgrade COP file how can i get it also is it the same sequence as upgrading Normal CUCM Also Can i rollback if anything happened THanks gu...
Hi All, We are turning up a LD PRI in a site ..but even after turning up the D channel it is not coming up. The switch type is primary ni2.Below is the current statusISDN Serial0/2/0:23 interface        dsl 2, interface ISDN Switchtype = primary-ni  ...
shyam2014 by Beginner
  • 592 Views
  • 5 replies
Good day, I have a question regarding the use of a POE switch.At this moment we have around 200 IP phones.All these phones use a power cube connected to the electricity.Our switches are not POE so I want to replace them by POE. My question is, is usi...
Hi I have cisco cucm ,There are cisco phones (7906) i just want  to try with asterisk server . so i created two vlans , one for endpoints other for asterisk server . What is the best practice running cucm and other pbx in an enterprise network . Do i...
susim by Participant
  • 505 Views
  • 8 replies
