IP Telephony and Phones
ラベル
フォーラム投稿
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator 投稿者 Community Manager
  • 6101 閲覧回数
  • 14 返信
  • 0 いいね!
Hello,I have created services and service profile on CUCM 10.5 and assigned to local user (NO LDAP SYNC) in user management>end user, but these users are not sync with CUP i see 0 users in CUP 10.5Any hint for troubleshooting.thanks
jack samuel 投稿者 Level 1
  • 547 閲覧回数
  • 6 返信
  • 0 いいね!
解決済み! Ip phone 7911 G
Hi all, i am a network administrator and security, we use in our company a cisco phone 7911G and CUCM attached to an active directory 2003, the problem that  we cant call with the name of users, just with the extension, i dont know where is the probl...
walidit01 投稿者 Level 1
  • 1591 閲覧回数
  • 15 返信
  • 0 いいね!
Hi guys.I have this issue when some of the calls placed in a E1 have echo.What I have be done so far is to change the command "echo-cancel coverage 24" to the values 128, 96, 24, under the E1 voice port config.But still nothing.Any ideas are welcome
I'm running Cisco CallManager System version: 8.6.2.25900-8 on our envirment and we are in the process of deplying a Cisco 8811 phone.Step i took Install Device PackReset TFTP servicesconfigure the cisco 8811 ph howevergetting error messageTelephone ...
Kyle Albasha 投稿者 Level 1
  • 926 閲覧回数
  • 6 返信
  • 0 いいね!
We need to deploy several new Cisco 7821 IP Phones.On our CUCM 9.1.2.10000-28 they are not shown as an available device and from what I could find we should install a device pack.Can someone tell me the correct version of the pack we need to install?...
kasper123 投稿者 Level 4
  • 673 閲覧回数
  • 6 返信
  • 0 いいね!
I have a weird problem that just started happening today. We have agents that can make a good outbound call then hang up, attempt another call and the call appears to proceed and the time counter on the phone increments but never connects. I have dup...
Customer is asking for a way for his users to access their phone's personal directories without having to enter a UserID and PIN#. Customer is on CUCM 10.0.1.1 using 78xx phones (sip78xx.10-1-1es5).Tried some of the methods posted for previous versio...
Is there a way in RTMT to see the active MGCP PRI B channels for a specific span?  It appears the only real time graph is a total count of all the active B channels registered to the cluster consisting of multiple PRIs, nothing span specific.  Any po...
pjsooner7 投稿者 Level 1
  • 902 閲覧回数
  • 2 返信
  • 0 いいね!
I've installed my first CME and I want to make sure 911 emergency services will dial correctly. We're using analog line into an FXO and I just want to be sure that it works. What's the best way to do this?Thanks.
AuxMax001 投稿者 Level 1
  • 25811 閲覧回数
  • 7 返信
  • 0 いいね!
トップソリューション
