IP Telephony and Phones
Labels
Hi, I noticed for the Cisco 6825 phone there are two firmware versions (as below) -- this appears to be the same naming convention where one has RGD and the other does not. I tried my best to work out what this means, but could not. The two advisorie...
GISVPN by Level 1
  • 906 Views
  • 2 replies
Hi everyone,Does anyone know the best way to remove the belt clip from the Cisco 6825 phone; other than just unscrewing it? I was wondering if there was a blanker plate or similar that can replace the void it would leave if just unscrewing it -- are ...
GISVPN by Level 1
  • 778 Views
  • 2 replies
I'm swapping out old 2911 with 8300 including an FXO interface for analog phone line.In "Add a new Gateway" in Call Mgr the 8300 is not listed in "Gateway Type."  Is there a generic choice that would work or do I need Call Mgr upgrade?My CUCM is Syst...
