Hi,Can someone please give me the steps to configure our Call Manager version 9.1.2 to be able to make 311 and 411 calls?thanks!
Hello,I am running CUCM Business Edition 6.1.2. I have an odd issue with the Service Activation screen in Cisco Unified CM Serviceability.When I try to deselect a previously-selected service and save, I get an error messages that states that "Connec...
What versions of Call Manager support the new VG3XX Voice Gateways?
I had a report from a user that they enabled the call forwarding feature on their line to another internal extension. The forward has since been removed by the user and they swear the call was getting redirected to the wrong extension they forwarded ...
Hello I have integration between CUCM v 9 and CWMS 2.5 , i have problem if i am going to do call me feature from webex . My CUCM is connected to SIP VG and my incoming calls and outgoing calls are ok , only issue to do call from my webex server to jo...
When doing upgrade to 8.6 it is not possible to rollback, explanation was that base OS was different (different version) and need a clean install.When doing upgrade to 10.5 (from 8.6 for example), there is also another OS (different version and even...
Is it possible in Call manager 10.5 to forward calls that are received from a certain extension but allow all other calls to be received as normal or to block calls that are transferred to a certain extension to another extension.
Hi allis it possible to configure 2 SIP trunks to the SBC of one SIP provider? The SBC has the same IP address and the only difference between the trunks would be the credentials.On a CUCM I can not add a second user in the same sip realm, so the cu...
Unable to connect Sony MDR-ZX550BN bluetooth headset to Cisco 8945 deskphone. It displays the mac address of the headphones but when i click connect, it says connect failed error msg"unable to connect to 00:50:60:xx:xx:xx. Any help
Hello Community, We've added new PRI to our single PRI. PRIs are controlled by a 7.1.5 CUCM via MGCP, we are using 3925 15.0(1r)M16 for gateway. Now, we are configuring SRST/mgcp fallback... I am wondering if i can assign the PRIs to a Trunk group; w...
We are running CallManager version 7.02 and just turned on our ftp server. All of a sudden, there are a bunch of files: cdr_StandAloneCluster_01_201502262251_2127..cdr_StandAloneCluster_01_201502262251_nnnn We cannot figure out what application in C...
Hi All, I have a question on 8841 phone with CUCM 10.5, when I call any number it is suffixing server name like XXXX@<servername and it is showing on 8841 calling party phone. Where can I make changes so that I can see only number
Folks, I have 8851 phones configured on CME 10.5 using latest firmware, 10-2-2. For the Call History, the "Recents" button isn't showing and apparently, according to the Admin Guide for the phone on CUCM, this feature is disabled by default. See bel...
I cannot get cellular calls to Sao Paulo to go through. Any insight would be appreciated. ! dial-peer voice 191 pots description Emergency Calling destination-pattern 19. port 0/0/0:1 forward-digits 3 ! dial-peer voice 9191 pots description Eme...
I'm going to make a test with the new CP-8811 desk phone, I downloaded the 8811 upgrade ".sgn" file and upgrade it to CUCM 8.5, but I can not find the 88xx series from the device list, I also tried version 9.1 and latest 10.5, unfortunately, 8811 sti...
| Subject | Author | Posted |
| 03-25-2025 08:49 AM | ||
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 2 | |
| 1 |
