Have set "Number of backups to store on Network Directory" to 1backup user has permissions to delete (tested with sftp client)but backup still keeps old backups. thanks
Hi , i am working with cucm 8.6 with Record Profile & Built in Bridge for recored voice session . how can i see a Summary phones that i configured forthat ? i triad work with dependency record on the cucm no luck . help on that please . thanks sharo...
Dears, I have 3 below doubts, In CUCM/CUC 10.5 onwards we don't require a security etokens (safenet or ActivIdentity,usb etoken ) for CTL file. pls confirm.I was installing 10.5 unrestricted version and I stop on the attached screenshot, if suppose ...
I've been reading about the new feature in CallManager 10.x where an administrator can lock or wipe an IP phone from the admin console. What model Cisco phones support this? I thought the 7942/7962 or 7945 would do this however I'm not seeing the opt...
Hi I'm having issues with getting a modem based card reader to work using an ATA190 on BE6k 10.5. I loaded the latest firmware available cmterm190.1-1-1-001, but I read that version cmterm190.1-1-1-003 fixed modem issues, does anyone know where this...
Anyone ever seen this? I'm running CUCM 8.6.2.20000 in my lab on Esxi5 VM's. Every time I gracefully shutdown the Pub and Sub, and turn them back on (this is a lab, hence the multiple on/offs) both Pub and Sub DRF local services never start. Never. D...
Hi, I cant get calls into the CUCM from a H323 gateway. Incoming external calls here out of service message or Number Unobtainable. I've attched logs if anyone can help? Rich
Hi I am trying to present an engaged tone when other callers are ringing whilst i am on the phone. I am logging onto my device via the Device Configuration and selecting 'Call Reject' on the DND Option, but it does not seem to work. Is that right? Ho...
When we transfer the calls from SIP Phones call is disconnected When a incoming call hits my 7821 SIP Phone while transferring the same to another SIP Phone call fails It is working fine with SCCP Phones Regards Vysakh.C.S
Dear All, There is a be6k in our testing lab, so we have tried to install the CUCM in be6k.However, the installation is failed as attached file. I am beginner in be6k and CUCM world, anyone has experience in this issue? Best Regards,Benjamin
I've got a peculiar issue. A client is reporting that their phone system is calling random people at all hours of the night. I ran a debug isdn q931, and sure enough, found where those numbers are being called. There is some strange output from the d...
Hello Team, Here is our scenario ,CME-------------UCM-------MGCP GW with PRIHere we want make the call from cme to outside organisation(PSTN),which should use the same PRI in HQ.we have configured the VoIP dial peer and pointed to call manager but c...
Greetings, I have a question in regards to the best practice when it comes to creating inbound dial-peers for a CUBE that would be receiving SIP calls from various sources (CUCM, CME, two SIP providers). Would it be best to create a dial-peer...
Hi, We are facing cisco 9971 IP Phone dialing issue, phone working properly but in a sudden one phone is not dialing external numbers same configurations working on same model phones. We have reset it twice tested with other sites configurations, it ...
Subject | Author | Posted |
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM |
User | Count |
5 | |
3 | |
2 | |
1 | |
1 |
