Resolved! cisco ip phone 7961 series
when I turn on ip phone, ip phone display on the screen just stopped in the process of upgrading is not up to the view menu .... I've tried pressing some buttons but not responding.what should i do ....?
We recently updated to CUCM 7.1.5.35901-1 and I noticed that when trying to update a "BLF" for an phone, the screen never populates to allow to modify changes. I f I try to update "speed lists" (for the same instrument) it comes back immediately. An...
Hi,Once a user closes the line (i.e. disconnects the call by putting the handset..), it takes 10 seconds to close the line.But if he presses “End Call” it will close immediately.This is happening with 7940 Model IP phones (as this is the only model ...
have the following setup:cucm 8.6cuc 8.6a cti route point (DN 1000 )with forward all to unity connection call handler.phone users who choose to have some quiet time can forward all their calls to the cti rp. 1. i need to allow only specfic DNs the a...
Hello,We are having cisco ip phones & third party sip phones in our company. both are registered to same cucm 9.X.Now when cisco phones calls sip Phones. we are able to see the alerting name on cisco phone.Say, Cisco Phone "Phone-A" calls Third Party...
Hello.This is my first time posting on here so hopefully this goes over well..I recently turned up a new SIP gateway (4451-X with PVDM4-256 module) and discovered a bit of an odd item in regards to my dial-peers.The carrier is delivering the number i...
Hello, I am at my wits end trying to figure this out. We have CUCM 8.0 at our main site and run an 1861 router at a remote site. The remote site is connected via a SIP trunk. Everything works except for MOH. When I look at the debugs I see that i...
Hello all,My company needs to migrate our existing SIP/VOIP offices off of our current platform to their new SIP platform. As a result we need to set up a few test DID's on the new platform. This means adding an additional SIP UA to our CUBE route...
HiI have one doubt my scenario is that i have a Cucm installed in my laptop in VMware and 2 ip phones are connected to it where both ip phones are connected to my ASA 5505 POE port , My ASA is my default gateway .DHCP is also configured in ASA giving...
Hello, I recently update to Cucm10.5 from cucm8.6.2 and now when I create a user in OU ( Active Directory) is not synchronize with the cucm and I cannot associate the new user with hrs extension.I see I receive : Warning: The selected Feature Group T...
Do these two applications do the same thing? If I'm looking at a tool for UC administration which should I choose?Any advice? Thanks, Joey
Hi there,we have an proböem with licensing on CUCM 9.x. There are some Enhanced Licenses. 4 of them are unused.There are also 2 Enhanced Plus licenses. These are oversubscribed with 3 so we have not enough enhaned plus licenses. Unfortunately the tim...
Hi,we have cucm 8.6 and cuc 8.6inbound call from ITSP transferred to CUC call handler for opening greetings and by pressing '0' it transfers to operator.i want to configure custom busy message when operator is busy with other calls.i configured anoth...
Hi,Setup has CUCM 8.6.2 on which all the phones are registered. And those phones are using CUBE as a gateway for PSTN calls (CME, as SIP trunk is provided by STC)60% of the PSTN calls are getting dropped and gets message from the CUCM: “your call can...
Hi all, I need to configure a new voice gateway, which has a connection to the PSTN over R2 signaling. The line is working, and I can receive incoming phone calls. For outgoing calls, I'm currently busy trying to get my translation rules correct. To ...
Subject | Author | Posted |
02-15-2025 06:25 PM | ||
02-14-2025 02:33 AM | ||
02-10-2025 04:39 AM | ||
02-07-2025 02:45 AM | ||
02-04-2025 01:17 PM |
User | Count |
4 | |
4 | |
2 | |
1 | |
1 |
