version: 11.5.1.11900-26 Section is: Search Call Handlers ->Edit Call Handler Basics (Standard) -> Greetings -> Edit Greeting (Standard) check the attached image file please. what is the reason?
HI everyone,Hope you all doing well. I have some questions about "Port Order with Microsoft Team" topic my manager brought up. Currently we are using Call Manager and Unity v11. We also use PRI (not SIP). We got a trunk of DID (with series of continu...
Hello everyone! I need to configure SIP TLS trunk between my CUBE and ITSP. Do i need to use PVDM, for conversion SRTP>RTP and back ? If i need to use PVDM, i have pvdm4-32 and pvdm4-64 in my ISR 4331, how to calculate the number of encrypted calls?
I just was assigned the task of administrating three Unity Connection servers that are networked. The Operator mailboxes on each system have been taking messages since 2010 and have over 5 thousand messages in them (nearly 3 mega bytes). I've correct...
I am dealing with a situation where my Queue enabled Hunt Pilot is not placing calls in the queue. The Hunt Pilot consists of 1 Line Group with 4-line group members and 1 Hunt List. Call distribution is set to Longest idle. Automatically Logout Hunt ...
good dayI have 10 IP Phones type 7975G, I tested the following 4 firmware on my CCME 8.6:cmterm-7975-sccp.8-3-3cmterm-7975-sccp.8-3-4SR1cmterm-7975-sccp.8-3-5cmterm-7975-sccp.8-4-2But IP phones do not accept any.I have downloaded all the firmware fro...
Our desk extensions stay with the role. Have an issue and not able to find the setting causing this. Ext 2220 is now User A and Ext 2221 is User B (was A). Only Ext 2220 has an RDP associated with it. After recreating RDP for Ext 2220, when that...
May I know procedure to test HA fail over test for the following servers: CUCM IMP CUC UCS
Hi, I have 1 cucm Publicher and 2 CUCM Sucriber (version 11.0). it work fineI upgraded the PUB to version 12.5, by now the 2 suscriber remain on 11.0After upgrade PUB to 12.5, I power off the suscriber, then some phone are registered and work, but so...
I have a Cisco IP 7942 on SIP firmware 8.5.3SR1S.It has been successfully registered on a external VOIP server.Not our server, of a service provider. They say they have tested the phone and it just doesn't work on their system. Incoming calls work,...
I have a Cisco CP-8865-3PCC and accidentally changed the connection method from HTTP to HTTPS and am now unable to access the phone's web server. Upon typing in its IP address, my browser (Microsoft Edge) just tells me "This page isn't working right...
Hello!I created 4 department which consist of IP phones and many PC.s and and 1 server part. After writing CLI of switches and routers, only 3 departments' IP phones were given IP address, the other one weren't given. Also, none of PC.s were given an...
Hi, The call forwarding for SIP phones is not working, if we forward the calls from one of the extensions to external number and we call the Direct Number (MSN) we get “The call cannot be completed” and from the debug we get this cause “Unallocated/u...
CME 12.0 | All 8841/51/61 phonesI have configured parameter external-ring bellcore-dr2 under voice register global (dr2 is the double stutter ring). We have all 8800 phones running the latest 14.1(1)SR2 firmware. The strange thing is that the dr2...
We recently got the cisco 6851 ip phone installed at our work place.We cannot access the voicemail system because it requires a pin code?Our local phone installer gave us a "temporary" code but it didn't work the second we put it in.Anyone have any i...
Subject | Author | Posted |
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM | ||
06-30-2025 02:50 AM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
