Hi,Hope you all doing Great. can anyone suggest me Good Link/Book to make integration with CUCM to unity and further configuration of Unity for Call handlers and Other Voice Mail Services. Regards-PK
Hi everybody! I heard that jabber can be used in phone only mode without the need of CUPS, but im wondering if it will work with CUCM8.6? I have seen configuration examples for CUCM 9, but there were some things that are missing in 8.6, like Service ...
Hi,I am getting below dsp errors on voice gateway router. I believe, we have sufficient DSP resources but still we are getting errors. I tried upgrading the IOS but no luck. We are getting the below errors almost everyday. Oct 7 10:59:20: %FLEXDSPRM...
Hello everyone! We are converting/moving two sites to CUCM 8.X ... One has the PRI that both use right now, all phones on both sites register now to CME which has the PRI on it..I am having trouble wrapping my brain around how to preserve that route ...
Hi everybody,I have a problem with the backlight on my phones 7821. The Backlight is always on and i want to put off after 10 seconds of inactivity. In options I have 3 box named "Backlight on Time" "Backlight On Duration" and "Backlight Idle Timeout...
We're currently using all calls for our secretaries to cover multiple DNs, which has been an excellent feature on the 9971s. We're considering migrating to the 8800 series phones for some of our offices where the 9900s are coming up on lease, but lo...
configuring as “Adjunct” to any end point how it consume less DLUs, How it works..kindly explain..
Hi Everyone, We are coming across an issue where a remote user via CIPC on VPN is calling an internal number but uses 10 digit dialing the problem is Call disconnects as soon as it is answered it disconnects also the CDR info for this call is a below...
I am attempting to recover a password on a MCS 7800 series server I have burned a DVD with the 8.5 ISO to use but whenever I put the disc in and have the IOS try to verify it it gives me the following error: FAT: invalid media value (0X72) I did a se...
Hello,In cisco unity connection version 9 what tool replace the remove subscriber properties tool that was in the early cisco unity versions. Like is there some commands in putty that could perform that. I have a user that was delete from the cisco ...
Hi,Can you please tell me if there is a way to adjust the T.303 H.225 timeout for a pots (ISDN E1) dial-peer?The local calls work fine but the international calls are failing with the following message:ISDN Se0/1/0:15 **ERROR**: CCPCC_CallOrigination...
I have always upgraded CP phones by placing the relevant files onto my tftp system, holing down # on the phone whilst plugging in the PoE connection and then typing the reset key sequence, after which the phone pops off and finds the files and upgra...
Hi,I have the following issue: when I try to dial a PSTN number, from the customer, using the G729 the call is not established and I'm getting a fast busy. The ISP is telling us that we should be sending a 488 after their Invite w/SDP.What I find str...
Hi Guys, The IP Phone 3905 have only 07 types of ring tone and I have the follow question: Is possible incresead this quantity of ring using xml or this configuration is native and not is possible change? Thanks,Wilson
I'm working on a 2911, with a ISM-SRE-300-K9 running CUE 8.6.7 (confirmed clean install). The CTI Ports are not registering with CUCM, all the steps have been triple checked, yet they don't register. The CUE talks to CM fine and pulls the 4 CTI Port...
Subject | Author | Posted |
01-24-2025 03:18 PM | ||
01-22-2025 01:28 PM | ||
01-22-2025 01:04 AM | ||
01-16-2025 02:00 AM | ||
01-08-2025 01:34 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
