IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5630 Views
  • 14 replies
Sip trunk between callmangers 8.5 - 10.5. calls work fine. But when we call from 10.5 side the other end is not getting calling name. it is getting the calling number. when I do a Sip trace, I see that 10.5 is not sending calling name in the invite.W...
pcromwell by Level 3
  • 167 Views
  • 2 replies
In case of upgrading Cisco call manager 3.3 version,as i know that with ics 7750 we can upgrade to the version 4.0,my question after upgrading 4.x to go latest version how migration happens ?what steps i need to follow? is it possible we can upgrade ...
 Hi,I have a router (IOS 15.2) running MGCP have caller-id enabled on our gateway and as well in CUCM. (10.5) I have this configuration for the ports and dial-peers.  voice-port 0/0/0 cptone TR timing hookflash-out 50 timing guard-out 1000 caller-id ...
Hi All cisco 7821 is configured with 8 speed dials however when you hit the down button it wil lonely show the first 6 ? anyone have a resolution ? You can still  dial the 7/8th speed dials but you cannot view them with the button (pressing down on t...
Hi One single  router and single isdn line , now added one more router and another isdn line  created a css named ' gateway_secondary ' and a partition created ' gateway_secondary ' and the partition added to the css  .There are phones which is under...
susim by Level 3
  • 739 Views
  • 11 replies
