I'm setting up the data from my BAT file for TAPs and I need to flag Extension Mobility as Enabled, I don't recognize where field to useIs there a field I can use to enable Extension Mobility for the phone device?
Hisome users are facing issues with connecting a call. when they dial using cipc the cucm routes them via sip trunk for which i have attached one packet analysis and logs below. the caller says that the call rings and then he gets fast busy tone. the...
Hi Team, we are facing one-way audio issue on hold and resume or conferencing scenarios. When CUBE on one call leg gets an OK with only one code (Ex. g711alaw), it offers all the codecs configured on an outbound leg instead of offering only the filte...
Wallpaper or IP phone background change in bulk using Common Phone profile in CUCM is possible only for 88xx series phones. However in 79xx and CIPC; user have to select the background from IP phone's settings menu. But we want to push the wallpaper ...
We have fax lines setup that are connected to VG224. Recently more and more of the fax lines just ring. We never get to the fax tones.We have been working with our provider and Cisco and no one can figure out what the issue is. And with VG224s bei...
Hi,I have CUCM cluster of 2 servers. i rebooted both . first i rebooted publisher and when it rebooted i rebooted subscriber. now i service activation i cannot see below listed services on the subscriber. RTMT says Cisco DRF Master as stopped by Adm...
Hi guys, good afternoon.I would like to ask for your help, because I have an EX with Software TC7.3.6 that is registered in Call Manager version 12 SIP Proxy1Status: RegisteredProxy: <ip-address-cucm>URI: DN@domainWhat do I need to configure to be ...
Has anyone replaced the Cisco Attendant Console with a queuing hunt group?We are moving our CUCM from our current provider to Cisco and we were told that the current CAC was going to have a lot of lagging because it is on our site. Right now our CAC ...
Hopefully somebody can lead me down the right path here: In our organization we have a Security Operations team that uses Jabber as a dialer for their desk phones. This way they are able to search for a contact and dial them using Jabber instead of h...
I have have two servers in a cluster: PUB is X.X.24.22SUB is X.X.24.13If I go to "services parameters" and select my PUB the CAPF service is not listed in the next drop-down box, but if I go to the SUB it's listed there and it's active. I've verified...
Hi there, I need to update the Dial Plan for Great Britain to include dialing to numbers beginning with 0204 and any other new numbers for the UK The latest one on the Cisco site is 3-1-35.GB If I look at the flat file I can see that this latest ver...
Hello. During learning the CLAUTO, I've created software for Cisco phones remote control. It is freeware. Attached. Tim.
I am officially stumped. I am running IOS 15.1, and CME 8.6 on my 2911. I have my CME router inside my main network (WatchGuard Firewall), and one of the interfaces on the CME router set as a WAN connection. My phones are also plugged into the WatchG...
Hi,Can the ATA192 be used as a termination for a PSTN connection and RECEIVE and forward calls to VOIP?Thanks,Charlie
Hello everyone,after I have struggled some days on how to upgrade a Cisco phone firmware, finally with the help with some friends in this forum I was able to figure it out, so I liked to make a video about how I did that in order to help other friend...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM |
| User | Count |
| 5 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
