Hello All,When I call from analog line to PSTN, call is going out normally.But after IVR telling me to dial extension number I can't dial. RegardsBahlul
Hello,We got two PAK's for expressway which is bundled free. When I applied one of the PAK on VCS the options changed to0 Non Traversal Calls, 0 Traversal Calls, 2500 Registrations, Encryption.Now I want to know where to apply the next PAK. I assume ...
I have about 40 phones that I had to delete, and then import a new BAT file for them with corrections. Now, none of the phones are registering. I noticed that when I imported the BAT file, CUCM already had IP addresses associated for the phones (I'm ...
Hi, Is it possible in CUCM 7.1.5 to setup call forwarding only in weekdays?Exampleif I have an IP phone and I have set up call forwarding to my cellphone after 10 rings I would like that to happen only on weekdays and call forwarding should not happe...
Hi All,I need to know if the new IP Phone 7821/41/61 can support CME 8.6 or I need to Upgrade to the latest version of CME to support that phones.If someone already did a deployment with a CP 7821 with CME 8.6 just let me know.Regards.
After installing a locale on a server, the install "Status" message says: "A reboot is not necessary for the changes to take effect." Yet the install log ominously proclaims: "WARNING: Locale changes MAY NOT BE FULLY AVAILABLE until the server has be...
Hello,Can both inbound and outbound call works for fxo connecting to pstn, running mgcp gateway?Appreciate your help. Thanks.
Hi all,we are currently starting to roll out some video enabled 9900 and 8900 phones in our network. In the past we did not use video and configured the access ports on our Catalyst 2960 switches with "auto qos voip ciscp-phone". This however creates...
Hello,I have two UCS C220 M3 servers that host CUCM, UCCX etc.The servers were built with the standard VMware 5.1 U2 ISO (VMware-VMvisor-Installer-5.1.0.update02-1483097.x86_64.iso) rather than the Cisco custom ISO (ESXi-5.1.0-1483097-custom-Cisco-5....
I have an issue setting up my RDP time. I wanted to have the start time Monday 17:00 and end time Tuesday 8:00am, and I would like to follow the similar pattern from Monday - Friday. What is the best solution for this task?
We require a setup of Hunt, on which one number will be internal call manager and other 2 will be external number.If none of the phone answer call should be redirected to voice mail i..e unity Let me know if this setup is possible, i have tested by c...
I'm trying to get a dx650 singed into UCCE 9. When attempting to sign in using Cisco Agent Desktop I get "You cannot log in because the phone is DTAL-enabled. DTAL-enabled phones are not compatible with CAD." There is no option for join across line...
When a CUCM is encrypted;1) It uses TLS for signaling and can fallback to TCP, correct?2)for UDP it uses SRTP , correct?3)any doc showing the encrypted ports uses? thanks
I use phone 7975G to register to CUCME by sip.7975 shows auth fail when it upgrade its firmware?I changed different firmware version. It still show 'auth fail'. I guess that it's not a firmware version problem.But what's wrong with my 7975.
All - I am trying to get a Valcom multi zone paging system to work. I currently can page all zones but can't page each individual zone. If I connect a butt-set to the Valcom, I can page each individual zone by pressing 0 for all, 1 for warehouse an...
Subject | Author | Posted |
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM | ||
06-30-2025 02:50 AM |
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
