Directory not showing in attendant console
I have added two new extension on CUCM, Directory not showing in attendant console even after resynch on CUCM and attendant cosnoleAny idea?
I have replaced my laptop with one running Windows 8. On my previous laptop running Windows 7, I used several Cisco Apps that I can't seem to install or run on Windows 8 such as Click to Call, Unified Video Advantage, IP Communicator, and VMO. Is th...
Question to experts/related to Cisco development team: when Cisco 78XX phones will get the right IOS to register with?
Hello,I migrated from CUCM 6.X to 9.1, Migration was successful with successful database restore, I changed the IP and Hostname of the server and server reboot automatically successfully, when the server came up i saw the extension moblitiy service a...
Hi guys,I'm trying to configure a T1 controller (VWIC-1MFT-T1) for voice which is installed on a 2651XM (12.4(15)T9).After I've set it up, it came up and the serial0/0:0 was created and was up. The problem is I can't find any voice-port in the config...
We have CUCM 7 and I need to connect an external ringer to a phone in the factory. I have setup an ATA directly to the ringer and shared the extention of the phone that needs the louder ring. However, as soon as I plug the horn in the ATA's red lig...
Hello ,Can anyone explain is there anyways to block only anonymous/Private/Unknown calls to specific DN's in CUCM 7.5.3?Regards,Ram
hii try to set up sip trunking between my CME 9.1 and toronto2.voip.ms. Please see the error below and the attached the router configs. Could someone help me to clear the issue.-- CAM_VOIP_RTR#sh runBuilding configuration...Current configuration : 22...
Call forwarding from a ip phone (7942) to external number is given a message the phone is no longer in service message. Call forwarding is performed using access code and prefix example 7.1(area code-external number) xxx xxx xxxx. Tried from both c...
HiI have a problem with calling name presentation when a call is transfered from one of my secretaries to another internal user, the original Called Party details are shown on the recieving phone.This is the secretaries query :- "If I picked up an ex...
Hello All,I have a problem. When i call on my pilot number or any other number, i can see cll disconnect message. PFA the logs below for your reference nd suggest a solution for this problem asap. the telco confirmed there is no issue on thier side.0...
We are currently looking at Office 365 for Email and possibly Lync. If our organization were to go this route how do we allow dialing from Lync back to our Cisco Phone system and Vice Versa? Video as well. Any thoughts on this?
Trying to figure out if it is possibe to release an extension for use again for auto-assign once a phone is unplugged. I test phones, mainly 79xx series, and it gets old fast having to do no ephone 1 2 3 ... when all of the extensions have been hande...
I am running call manager 8.0.3.20000-2 on a MCS 7825 I4 can any advise on the upgrade path please?
Can you help me undestanting how to uses the calculator?The first issue I found is how to make it work with PVDM3 or VWIC3, then what do I need to write in each part.Finally how to interpret the output.I want to know if whit the below information I c...
Subject | Author | Posted |
03-22-2023 02:46 AM | ||
03-21-2023 09:21 AM | ||
03-21-2023 09:15 AM | ||
03-19-2023 11:06 AM | ||
03-16-2023 07:10 AM |
User | Count |
13 | |
10 | |
8 | |
4 | |
1 |
