IP Telephony and Phones
Labels
Hello.We are having issues with 1 hunting group that has 2 phones in it.We have just two extensions in that hunting group but the call just get to one of these ip phones.Both ip phones are different models. 1 is a 7942 and the othe is a 7965. The fir...
Hello all, I am trying to create an extension that will get through to a handset here in our office and will display a message to the effect of "IMPORTANT INCOMING CALL - PLEASE ANSWER" and have that linked to an extension that is only known inside t...
Hi. On page 143 of the official ccna voice cert guide there Is an example of a translation profile where calls from the PSTN with DID range of 6xxx should be converted to 5xxx to reach the internal network.There Is an explanation of why the called ru...
Reprovoid by Level 1
  • 423 Views
  • 2 replies
Hi all, We are trying to communicate two clusters using Cisco IPT endpoints and Jabber clients. It works fine with Non-Gatekeeper Controlled trunk, but not with a Gatekeeper Controlled one. Also, the trunk works fine with Cisco IPT to Cisco IPT calls...
