IP Telephony and Phones
watch here Journey banner_2
Labels
Hi,I have a Cisco CCME with a SIP-Trunk to an external provider. Incoming calls over this trunk are forwarded to a Cisco Unity Express IVR (running on a SRE), which - depending on the users DTMF choices - forwards the call to the chosen internal exte...
When trying to press * or 4 during cisco greeting from an external caller it is getting ignored. Internal works fine.I read somewhere about the voice gateway dmtf settings but I believe I have all the correct info.Here is some of the running config o...
eklock by Level 1
  • 1510 Views
  • 12 replies
hi everyone    PBX(3xxx) ---- E1 --- CME --- IPT the call from PBX , calling : 3001 ,called : 71665 i want match "num-exp 71... 7171... " , and then match the dialpeer 71000, but is didn`t work , is there something wrong with the config ? pls hlep me...
Walk by Level 1
  • 707 Views
  • 3 replies
Hello, Recently had a h323 gateway hacked and fraudulent calls were made out of the gateway. The Gateway has a T1 PRI to telco and LAN ip is private protected by firewall. I am assuming the criminals were able to call the company DID number, enter so...
mannycho by Level 1
  • 939 Views
  • 5 replies
Good day,After having made the following configuration, as soon as I dial the number 45290216 the extension 4001 rings so I can make the communication without problem, but the IP Phone 4001 does not display the calling number it displays the message:...
I use an 8851 with one KEM at my work office normally. Have been remote at my home office which is using a Meraki Z3 provided for work network access. Phone works fine when connected to PoE port however the KEM does not. Any thoughts or suggestions t...
ExuroFire by Level 1
  • 2075 Views
  • 7 replies
