IP Telephony and Phones
Labels
Hello Everyone!We are having a problem when someone calls into the main number and the receptionist tries to transfer the call to an extension (this only happens on 3 extensions on a VG224) it gives her a fast busy.However, if she dials the extension...
I need some calrity, the cost is huge.  When I'm doing CUBE.  Assuming I'm running G.711 on both sides (no transcoding) and I don't need any MTP (conferencing, etc.) do I need DSPs on a CUBE router?  Does DTMF inband vs. out of band have any affect? ...
ncowger by Level 1
  • 501 Views
  • 1 replies
Guys, Im struggling with Owner User ID and Extension mobility. It seems to me that unless we set Owner user ID on every single hardware phone, it uses an extra license.  Why would you set owner user ID when you are using extension mobility? The whole...
hi,
i have a remote control for a SX20 Cisco that doesn't respond unless i get closer the remote to the signal led at 1 cm.i have change the batterys, i have change the remote but with the same result.i think that the codec has something.is it necessary ...
cfacquez by Level 1
  • 801 Views
  • 6 replies
