Dear All,Am using CME with 9971 SIP phones. Is there way to configure these phones through GUI like SCCP phones?? Please suggest
Hi,Our customer is planning to upgrade from ver 8.0 (MCS) to 10 (Virtual).Is it possible to use call manager as VM on any brand server ( not UCS ) ? the goal is to reduce the cost for the upgrade.Regards,
HiIn my company , we have the CUCM with the version the system version 8.5.1.We have many device types but the problem only exists in the CP-7941G .In the call manager ,the "User locale"is configure "Portugues,Republica Portuguesa":User Locale< None...
Dear All,We have implemented a few VG224 in an Hotel environment and have experienced the following issue :At times, no tones are heard on some analog phones. The show stcapp device summary shows that the concerned voice port is in VMWI_DSP_SETUP cal...
Hello.We are configuring billing on a third-party server for a hospitality projects.All is fine so far. However we saw that calls with zero duration (such as missed calls, busy tones etc) are tagged with a wrong timestamp of 1/1/70.Since we are passi...
Hi,My boss has two companies registered under his name and the two companies are sharing same office. We have two phone numbers from comcast, and going into FXO-1 and FXO-2 ports. We want to use one number for each company. (number A for company A an...
Dears,I have CUCM 9.1 with Cisco 2901 Voice Gateway (MGCP), I installed a FXO with four ports regarding the PSTN access.Now I need to assign an internal Extention for Example (1103) to access PSTN through only the port (voice-port 0/0/0).Appreciate y...
Our default “Wait time overflow” is set to 1 minute for all sites. I have edited the time for 2 sites to 30 seconds. If you modify the “Wait time overflow” do you then have to Synchronize with CUCM?What is actually being synchronized between the Atte...
Hi allim using cisco 2901 has a MGCP Gateway whit FXO ports on a remote branch office.When the Gateway is connected to the CUCM all works fine but when the Gateway disconnects from the CUCM it goes into SRST mode:In SRST Mode the outgoing calls works...
Hi GuysDoes anyone know if the CDR data on CUCM 9/10 includes average wait time and abandon rate?CheersMike
Hi All,Does anyone have any ideas on the following?There are two CUBEs with a SIP trunk on each, the second is an SRST gateway with ISDN.The CUBEs are configured in CUCM as SIP trunks.Is there a way to try each CUBE (SIP trunk) first the the second C...
I am new to Jabber I am planning install Unified IM &presence server for 150 users,Below quanity are oredered Description QtyJAB-VOICE-ADR-UWL =150 JAB-VOICE-IPH-UWL =150JAB-MAC-CLNT-UWL =150 JAB-DSK-UWL=150JAB-IPAD-UWL=150WEBE...
Inside my corparate network we are using meraki firewall,i have configured manually vpn in my phone instead of any connect to connect vpn,trying to authenticate cisco jabber client from android device i am getting an errorConnection timeout.Even i tr...
HI ALL;I AM IN SERIOUS PROBLEM. I AM USING C220-M3 ucs server and have been deployed two servers. CUCM 9.1 AND UNITY CONNECTION.Unfortunately, I cannot connect to vsphere. I retarted management agents , management service but problem is same. I also ...
hello , i have CME installed on 2900 router , incomming calls are working fine but i can dial PSTN calls.below error is comming in Debug: Outgoing call from gateway: gives diconnect cause value = 34 no circuit
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
