I have a CME and CUE setup. When an outside caller calls, their DTMF inputs are not recognized by the CUE.I am attaching Copies of both configs.
Hello , i have cucm 9 and my request is as under : 1 - User can dial PSTN in working Hours without any pin code2 - user asked for pin code after working hours and user also able to change the pin code. any idea please
Hello , we have CUCM 6.1 , and unable generate CDR report of more then one month . i getting Error 40006 saying u can generate report for a month or less then a month . how i can configure the report duration for more then a month . please advice .
Hello , i have CUCM 9 , and call PICKUP is not working . on DN callPICK group is selected . any idea .
Hi All, I am getting "Cause i = 0x80FF - Interworking error; unspecified" code in isdn debug. Call flow is : IP PHONE --> CUCM 8.5 --> SIP TRUNK --> CUCM 9.1 --> MGCP GW --> E1 --> PBX --> Phone CfdAll to intra cluster DN Called DN : 87061725 Calling...
I have a CME and CUE using SIP as the PSTN. I have it configured to receive and place calls with no problem. When I call the voicemail or Auto attendant from the inside phone, it works fine. When I receive a call from the outsdie, the transfer to ...
Few questions need to verify, and hopefully someone can provide me documentation related to ASA 9.x- is UC proxy configuration on ASA 9.x still supported?- are there changes in the configuration of UC proxy on ASA 9.x?Appreciate all the help you can ...
Is there any way to batch import Directory Numbers and (individualized) descriptions for each number using the BAT tool? It seems there must be a way. The range-add function under DN management won't work in this case because the numbers and descri...
Hello, I am Amadou Dia CCNA Voice. I had a cisco telephony project to deploy in 3 sites (One CME 2911 and two CME 2901). I did the deployment correctly, now my problem is that i have many 6911 IP Phones in the deployment and i would like to know ...
HI, I'd like to be able to route \ translate incoming calls based on the following field in the sip message. From: "Bob" <sips:bob@biloxi.com> ;tag=a48s From: sip:+12125551212@phone2net.com;tag=887s From: Anonymous <sip:c8oqz84zk7z@privac...
Hello All,VM is not being delivered to user's Outlook, when anyone tries to leave a message it disappears in a couple of minutes and does not get delivered to Outlook, message count from Unity Admin page shows 0. If Unified Messaging is disabled the...
I have been looking for an install / upgrade guide for Cisco Unified Enterprise Attendant Console. I need to complete an upgrade from CUEAC 9.01 running on Windows Server 2008 Standard x86 to CUEAC 9.1 running on Windows Server 2008 R2 Enterprise x64...
Hello AllI am trying to clarify if 6921 et all phones support the sccp protocol in ucme 9.x.From the ucme administration guide it mention support for these phones via sip and doesn't mention sccp.Cisco Unified CME 8.8 and later versions support the f...
I apologize if this is a stupid question, I'm an Avaya voice (cisco data) guy, I'm still learning Cisco voice.I've installed an analog polycom soundstation 2, I can make internal and external calls. However I can only receive one incoming call at at...
Our client is requesting that when a call goes to voicemail and the person that is calling in dials "0" the call goes to the local operator. We do that in CUCM with calling search spaces and partitions. But in unity we have not been able to figure ou...
Subject | Author | Posted |
05-20-2025 07:57 AM | ||
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
