IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5811 Views
  • 14 replies
As I understand it, a mobile device such as a laptop, tablet, phone etc. uses Mobile IP to connect to "foreign networks" when away from home. My question is this, does anyone know if ALL traffic is routed/redirected to the "care-of address" by the ho...
Hi all,I have a question in order to modify in a massive manner the field "Calling Search Space" inside of the option "Directory Number Configuration".There are a lot of phones that doesn't have the correct CSS, and I need to change it, but are aprox...
Hello We are facing issue with CME time , Phones are getting different time on phone displaySome phones are getting wrong time after the reload of CME including CIPC. But the same type of (7942,7945,7970) phones are getting proper time some of them ...
Shaijala by Level 1
  • 4494 Views
  • 6 replies
Hi,I have a weird Unity Connection Voice Mail issue and would appriciate any help i can get. Many thanks in advance.I have Unity connection 7.0 and CUCM 7.0 integrated in a lab enviroment and here is what happens.When I place a call internally say fr...
sizene001 by Level 1
  • 809 Views
  • 2 replies
The thing I struggle with most is getting the correct parts.  I have spoken with two VARs and gotten two conflicting answers. I thought I would open it up here.I have a remote site that is very small.  I plan to purchase a 2901 ISR to configure as th...
I have cucm 8.6 running in my environment. I am trying to do some bulk update on a number of phones to change their device pools. However, when I choose BULK ADMINISTRATION->PHONES->UPDATE PHONES->QUERY and search for the phones I want to change thei...
Hi, Currently work on multiple LANs designed for data. 6509 cores linked together using L2 POs. All HSRP/ OSPF Adj are via these links.Ive recenly read ideally VoIP needs L3 connectivity between cores, and distribution layer. L3 dist is a non starter...
Si by Level 1
  • 343 Views
  • 4 replies
