Hello Guys,I have an issue with CUCM LDAP Synchronisation, it happen only once a day even if it's configured to be done each 6 hours.Next Re-sync Time (YYYY-MM-DD hh:mm) shows that the next Sync will be done after 24 hoursAny Idea?
Hello, friends!After rebooting the phone 7965 does not get ip address. DHCP works 100%. Did a factory reset. But did not help.
I have a PA who has both her bosses lines terminate on her phone as line 2 and line 3. Is there a way to Call Forward All the 2nd and 3rd lines by pressing the CFA button? When I select the line the Call Forward All button is greyed out. I'm running ...
we are experiencing a problem on phone 78xx series when transfer a call.When the 7861 telephone transfers a call and the called party does not answer, can not resume the call on hold.I configure my sip profile in any particular way?
Hello , When I try to import new user via exchnage I get new window but it's empty someone know what is the problem ?
Hello, I've been trying to get a basic set up working with the 861w where this is being set up at my home with a 7940 IP phone hooked into it to go across an EZVPN tunnel to connect to my office's uc560.Now, I have an ASA5505 which works fine, but I'...
Hi,I have a user who forwards his calls when he's out of the office to his cell phone. When he gets back into the office he turns off the callforwarding. However for some strange reason external calls placed to his number still get forwarded to his...
Hello all,We need to expand on the voicemail ports in our Unity connection. We plan on using the wizard to add the ports we need but just curious, is there any downtime involved when we add ports?Please let me know if you do.Thank you.Rgds,Vicky
Dears,i have cisco asr router 1006 and i need to check the license cube license.i tried show license but it doesnt accept the command.Please advise how to check the cube license and its ersial number.BR,Haytham
Hello All,Sorry to ask this questioon. We are palnning to upgrade the flash size for 500 gateways. Is there is any device to copy files from PC to Flash? like copying files to pendrive.?-Murali
Hi, I am facing problem with mobile connect timers setting. Consider the scenario...i am in canteen some one dials my ip-phone no. i get a simultaneous call on my mobile also....now i reach to my desk while talking on my mobile and now i want to tran...
Hi, hopefully i'm posting this in the right section.I've been asked by someone if its possible to increase the amount of logs held in the "placed calls" section.He says its convenient for him to keep more as when dialing a number, ...
Dear expertsI configure my PBX server to work with one VoIP provider. When I put the server in blank network, mean that without VLANs. The IP PBX server can register to the VoIP provider system normally and I can make call out and receive calls norma...
Hi I have a problem with IOS of Router 3825 that not display the interface fxo in "show Run" . But when i do the "show version " , FXO interface founded .I think i have a problem with the IOS that not support FXO Interface . I need a IOS that i...
On a 3845 running 12.4 20, the DTMF tones (for menu options) are not getting passed from the PSTN into the network after the call is established. The router is using CUBE software and passes the call to the PSTN via SIP trunking/SIP server. The cal...
| Subject | Author | Posted |
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
| User | Count |
| 1 | |
| 1 | |
| 1 |
