IP Telephony and Phones
Labels
Hello,      I have cisco 2911 Router on which is installed with CUCME 9.1. I downloaded the load files and installed it in the tftp server, created DN and also created the Ephone with Mac address of 6921 phone.The phones boots and says not registered...
skakfinn1 by Level 1
  • 556 Views
  • 3 replies
Resolved! Mobility on CUCM
Hii,I activate the Remote destination and Remote Destination Profile for my extension but I want after 4/5 ring on the desk phone the call to be transferred to My Mobile, is working after I checked theEnable Mobile Connect. The problem is that it ri...
gabiulici by Level 1
  • 470 Views
  • 2 replies
Assuming the callee phone number is 1111.    It is the callee number.   The phone is registered to CUCM 8.6.2.The call is initiated from outside via CUBE.After the call hold, when the Resume is pressed, the CUCM send Re-INVITE with callee extension t...
DearsCurrently we are running in 8.5 BE. i installed fresh 9.1 and exported all phones from 8.5 to 9.1 successfully. after rebooting the phones they are registering successfully to 9.1 but they are pulling the new load file of 9.1 they are still on o...
lambay2000 by Level 2
  • 1786 Views
  • 17 replies
Resolved! WebEx
Is it possible to add the WebEx service in the Excising blade server? If no what are the additional hardware /Software /Licence required can anybody suggest me
I have BE6K where Callmanager,unity,Im running on VMware in UCS220 m3 server,plan to have redudancy for all the three servers,should i go for another BE6K for redudancy purpose? can anybody suggest on this
I've recently starting experimenting with Cisco Call Manager (version 8.6).  I've been able to figure out routing outgoing from the one extension I have setup, but I can't seem to figure out how to route incoming calls to that extension.  I'm running...
Hi,Can anyone tell me how/where Certificate Information (Organization, Unit, Location, State, Country) can be accessed from CUCM web interface or the CLI?I'm searching but so far not finding it...Call Manager 6.1(5)Thanks Steve
ciscology by Level 1
  • 8948 Views
  • 3 replies
Hey,I notice that the BE6000s have the "Onboard SCU Storage Support" BIOS option is set to "Disabled" making it impossible to boot from the Flexflash SCU partition to run diagnostics before deployment. If I set this to "Enabled", run my diagnostics, ...
