IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5892 Views
  • 14 replies
Hello, Need some help. We have a bunch of DID's that have a number 424-865-63XX and we want to change the number when called to a different extension when it is called. For example, when someone calls 424-865-6380 we want it to ring on internal ext 3...
gavinr98 by Level 1
  • 918 Views
  • 7 replies
  • 5 Helpful votes
I'm currently migrating to 4331 ISR's from 2800 series routers. Has anyone had issues with the  NAME: "NIM subslot 0/2", DESCR: "NIM-2FXS/4FXO Voice Analog Module"PID: NIM-2FXS/4FXO , VID: V01, SN: FOC20375GE1 NAME: "PVDM subslot 0/4", DESCR: "PVDM4-...
nbspooney by Level 1
  • 3532 Views
  • 11 replies
Hello!I need to check some client for correct auth.I make small tools for it:https://github.com/OlegPowerC/SIPdigestCalculatorUsage:SIPdigestcalculator.exe -u username -r realm -p password -n nonce -uri SIP URIorSIPdigestcalculator.exe -u username -r...
Hi cisco I received one request for voice mail in unity connection with a scenario :once a customer  call extension from 1 pm to 2 pm the customer should be hiring the voice mail directly once a customer  call extension after working hours and weeken...
I have an older ATA 191 that i am trying to get Multiplatform Firmware loaded too. The existing Web UI does not have the options under the administration area to send the command to update from a local TFTP. I also found a couple deployment guides th...
Hello Everyone,i have a wired situation with my customer about Cisco jabber call over VPN of forti.when user call to external number from Cisco phone that register to his LAN the calls work perfectly.when user call to external number from CSF Device ...
iptsupport by Level 4
  • 1249 Views
  • 2 replies
  • 25 Helpful votes
Resolved! cisco 7965 phone
I am now working from home.  I was given my CISCO 7965 phone to use.  When I plugged it in to my ethernet cord coming off the modem, it would not power up.  Any ideas?Shouldn't it just plug in and boot like it does at the office?  Doesn't it have its...
