IP Telephony and Phones
Labels
Hi all,I have just configured two isr 39xx as cube and both in HA following the configuration guide in the following linkhttp://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080b40d82.shtmlafter configured everyt...
Hi AllWe have cisco voip environment and sometimes users complain that when day call outside there have no audio. There is no audio on IP Phone and Mobile. Call is going outside via H323 Gateway using ISDN PRI. We can see IP Phone is transmitting pac...
Dear Experts,One of my customer has a requirement:when an ip phone extension is called, and if the user is busy the system should play a message that the user is busy and prompt to leave a voice message. The voice mail must be delivered to the called...
i have switch with cucm on port 1/0/4...need to apply qos... as per question..setup is wit 3 sites...and over framerelay..site -3 have cue...site-1 have cucm with this switch..configure switch 1 with policies on the 3750 switch:1: ensure cos value 5 ...
Amit23 by Level 4
  • 1509 Views
  • 2 replies
Hi,In our Call center we are facing one way voice path.Users complaining that when the call comes from Customer side,they are not able to hear.It's totally blank call.So,could you please let me know from where i will start troubleshooting ?Call flows...
sbatsya12 by Level 1
  • 575 Views
  • 2 replies
Resolved! SIP Failover
We have a two data center environment (primary and DR).  Each site has a CUCM subscriber, a cube router with a SIP to Verizon, and a PRI router.  Primary site has the pub.  This environment is 100% managed by a managed service provider, so my questio...
