IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5538 Views
  • 14 replies
Does the voice stream of a Jabber client have the same QoS markings as a phone like the 7900 series or is the voice best effort over an on-premise network?
Resolved! COR configurations
Hi, guys.I have dial-peers well configured, ephone-dn done, ephone registered and all is working pretty fine.1. Below is an example of each of the point above:dial-peer voice 1 pots description OUTSIDE preference 3 destination-pattern 900T port 0/0/0...
HiI want to configure a Queuing with CCM 9, I know that this is with a Hunt Pilot and as destination pattern put the trigger to CCX and launch the scripts, but in my case customer does not have a CCX, only CCM 9 with CUC9, so how can I manage the scr...
Dears,I have set up presence and Jabber 2 days back and i tested everything for 2 users and it was perfect, after 2 days i came to finalize by adding more users before adding i tried to login by same users but and i am not able to login. I get the be...
Hi allI have the following setup :PSTN--------SIPTRUNK -------2901----H323-------CUCM8.6-------InternalThe outbound calls not active in this session as per my managment requestsThe direct call for each extension is fine 22846XXif somebody from out si...
I recently purchased and installed a SX20 bundle with the new 2.5x PHD camera after reading the camera had a microphone integrated (thus removing the need to stow/mount a wired mic). However, upon doing intial testing I wasn't getting any audio, and ...
We have a CUCM version 6.1.1.3000-2.I know that this version will not support Webex soft phone.Would like to know if there is any way to register Webex with this version of CUCM,eighther via updating any patch file or something else.Please help.
I have multiple Cisco 7937G conference station along with Mic-Kits for larger rooms installed in offices. When we make a call from the 7937 conference phone the person on the other end describes the caller sounds like thinny, hollow sound and very sl...
