IP Telephony and Phones
Labels
           Hi  I'm facing a problem with cisco 8941 running with SIP. First it was connected to my CME with sccp; it's working; but without video, I have to configure it to work with SIP to get video.here the sip configuration voice register dn  8 nu...
Hi Guys.For Cisco Sip phones,is all what needed for srst is to add the srst reference in the device pool?For sccp,it works normal ,i put the the same srst ip of sccp in the sip field,Is that all what needed ?For 3rd party like Avaya,Polycom,GrandStre...
Dear All, Either I did not search long enough, either there aren't a lot of questions on it, but would some of you know how to enable the transmission of RTCP-XR packets on IOS based gateways? There are a couple of really ingenious monitoring systems...
jbollen by Level 1
  • 704 Views
  • 0 replies
Resolved! Khizar@tcs
  Hi,                               I have a hunt list with 7 extns configured. However when the same is used, the calls are looping between the first 3 extns and then it rings all the extns...The algorithm used is Top down. I want all the extns to r...
Anyone out there might help me to point on the right direction about why the top down did not work automatically when I shutdown a voice-port E1 in the first gateway listed on route group? However, it worked when I manually changed the priority from ...
