IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5546 Views
  • 14 replies
Hi,I have CME 9.0 with 6921 IP phones, I have a problem when I set CFNA  ( call forwar no anwer) to external number, after the timeout the call is drop.is weird because I can set CFA to external number and CF busy to external number and both work fin...
Hello,     I am also having issues with the same Cisco 2821 CME system.  Some extensions are unable to get audio from calls coming off of a parallel hunt group.  This started with extension 1100 and 1101, but now 1102 is also affected.  I have been a...
mikeh by Level 1
  • 623 Views
  • 2 replies
Hello,     I am running into an issue with my CME/CUE configuration where whenever a caller tries dialing an extension during the AA announcement (or from the dial by extension menu option), they get a message (I'm guessing from CUE) that the subscri...
mikeh by Level 1
  • 1337 Views
  • 5 replies
Hi,I would liket do seek everyone's assistance on my problem above. I have already tried solutions I found on the Cisco website and other sites. It was working before but we had to change the CUE hardware due to some sector issue as per Cisco. I have...
hello all,In our sysytem,we are facing one issue,ie calls are going in browser timeout VDN ,but we are  not  getting any logs(error) in cvp vxml applicationwe are using CVP7.how come calls will go in appication timeout without writing logs in servers...
Hello I am trying to find capability to setup CME on ASRs.I would think this would need something similar to PVDMs depending on the number of IP Phones that are to be serviced.But I do not think there are PVDMs capability for ASRs.I found something s...
I have a CUCM 8.0 with 100 phones and I want to change the background of all the phones. I know how to do it going one by one (settings, user preferences, change image) but I want to know if there is any way to change the default image in all the pho...
Hello Cisco Professionals!I noticed my clocks are not correct in Call Manager. (System > Time/Date Group)Can I change the Time Zone without hindering a live enviroment?Or is this something I should change during downtime?Thank You for any information...
TheGozer1 by Level 1
  • 557 Views
  • 2 replies
