IP Telephony and Phones
Labels
Hi Guys,I have Vg224 using sccp registered to cucm ,in srst mode i had to create dial-peer with destination pattern to match the number of the fxs port .Now after cucm returns online the router uses the dial peers with less preference over the dial p...
All,I'm having an issue that I can't quite resolve.  The layout is the following: Asterisk <--SIP--> 3845 <--H323--> CUCM 8.6From all IP phones registered to CUCM we can place calls to phones hanging off the Asterisk server.  When phones hanging off...
srpm by Level 1
  • 1387 Views
  • 4 replies
Resolved! VG224 IN SRST
Hi guys.I get fast busy tone on the vg224 ports when it works in srst mode here is a sample of my config:application global  service alternate Default !interface FastEthernet0/0 ip address 192.168.91.210 255.255.255.0 duplex auto speed autoip default...
Hi AllIs is possible to install a Symantec backup agent on a CUCM 8 server and let that handle the backup or do i have to use the build in backup to SFTP? i goes for Unity as wellKind regards Niels
in srst mode , is there any method that could retain the default display on bottom of 79xx ip phones which is (your current options) instead of the message that appears in bottom on 79xx series (during the srst mode) which is (cm fallback service ....
msulieman by Level 1
  • 9985 Views
  • 3 replies
Dear All,     When I call to extension on which I am facing the issue it ring 3 times and then issue come as I mention in the subject. Any one knows about this issue, I am checking the issue but not sure what can I do to make stop or to make ring mor...
i have a scenario where incoming calls through PSTN need to be translated to a UK toll free number and going out thorough a SIP trunk provider.Please let me know if the below mentioned config on Voice GW is Ok for this purpose.voice call send-alertvo...
SJ SJ by Level 1
  • 398 Views
  • 2 replies
