SRST issues after CUCM/Unity Connection to release 9.1
Has anyone experienced issues with SRST after upgrading CUCM/Unity Connection to release 9.1?
I currently have acquired a 3825 ISR router, and here is a show ver of the config:USRMIHQ#sh verCisco IOS Software, 3800 Software (C3825-ADVENTERPRISEK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)Technical Support: http://www.cisco.com/techsupport ...
I have 70 or so phones registered to my CUCM 8.6.2 cluster Subscriber from 3 remote sites, and 25 phones local to the site where the Pub and Sub are installed. those 25 phones are registered to the Publisher. All remote sites are connected by MPLS. O...
Few days ago, I was trying to access to telephony service, but suddenly appears this: I don't know what's going on, first try to change the browser, then try to change the IP, update the service. but nothig worked.I've made a debug when I trying to a...
Can someone tell me if the following setup will work? Current setup:2911 Router(2) VWIC2-2MFT-T1/E1 cards supporting 4 T1’s for data. Cards exist in EHWIC slots 0 and 10/0/0 and 0/0/10/1/0 and 0/1/1(1) PVDM3 DSP 16I am implementing voice so I need to...
Hello guys!Wich is the best way to restrict phones that will register when in SRST mode? The scenario is a CUCM8.6 and a Cisco 2921 as the SRST gateway. I created a new device pool with the srst reference configured but phones assi...
Good morning.I'm trying to create a simple script for ivr session on cue. but I've a little problem.I need to have a simple script :The call arrive in a cue the script is verifying if it is a business hour closed and then pla...
Hi ,We have recently migrated from UCCX 5.0 to UCCX 8.5(1)SU3 , but post upgradation we have observed that calls are not getting recorded and when i try to open recordings supervisor desktop it says "no recording files found".I have also disabled "ad...
Hello All,Is there any workaround to change to First name "first" in the corporate directory on CUCM9.0?Corporate Directory displays the user names as follows: Last Name, First NameI would like to change it to the following format:First Name, Last Na...
Hello,We have a customer which has a LOT of call pickup groups configured in their CUCM cluster. From time to time (every week more frequently) a pickup group stops working normally: One or more of the group members cannot capture calls anymore, and ...
Hello All ,does anyone one have training or Document how to install and configure : Cisco UC Virt. Foundation 5.0 on Cisco UCS Servers (C-series )
Hello guys,We have a CUCM 8.6 cluster and we are trying to communicate with an Avaya Ip Office.There is a 2921 gateway registered as an MGCP gateway in the CUCM and this gateway have a QSIG E1 to the Avaya.Calls are working in both directions but the...
Using Cisco wallmounts we can mount the phones vertically and all seem fine. On a vessel however with big waves, the horns tend to fall off (also when the hook is reverted). I know that these phones are on board of US navy vessels and I am sure I am ...
Has anybody been able to configure a Cisco 7942 IP phone with an Allworx 6x? Thanks.Shane
Hi I have done the after-hour configuration with CME 8.8, phone number is blocked using after-hour config, but its not requesting a PIN to by pass the blocking, I have entered a PIN command under ephone also. part of the config is bellow. !telephony...
Subject | Author | Posted |
02-06-2023 10:54 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM |
User | Count |
10 | |
8 | |
4 | |
4 | |
2 |
