Hi All..Perhaps someone could help...I have an issue with the GUI when trying to access the CUCM admin web page on our subscriber server.I enter the username and password but then the web page just hangs and the IE progress bar gets very slowly ...
How to get the configuration file of a phone from cucm (9.1) ?I have a polycom sound station 7000 that registered to call manager and i wanted to see if this phone has a configuration file used on call manager cause i have an echo problem with it and...
Hello , I want to upload new firmware to ip phone 7962(CUCM 8.6).I uploaded the file to the os ,but when I eneter to device>device settings>device defaults .I don't see the new version .What I am doing worng ? Thanks.ben,
Hi, I have a customer who has a Cisco Communication Manager Express 7.1 with Cisco Unity Express 8.0.5. My customer wants only for the international calls on specified destination numbers put limitation with the manner below:If the sum of these calls...
Hi,I have an issue with some IP phones I just deployed. I have a voice vlan and data vlan configured on my core switch. I also have my DHCP server issuing IP addresses to my computers and the core switch issuing IP addresses to phones. This is clearl...
We have CUPS 8.6.3.10000 and CUCM 8.6 is on production.Configured Cisco Jabber 9.0.1 for windows and able to login to Jabber.Integrated with LDAP, CTI Gw, CCMIP, CFS all are created.Problem I am facing in Jabber is for any user under communication i...
Hi TeamAny suggestions on how to troubleshoot beep tone on some 7942 Phones?The problem is intermittent. We have a UCCE Setup and calls are auto answered. For some incoming calls the 7942 produces a beep before the call is answered. Its something lik...
Hello,I have a strange issue. When pressed Directory list on Cisco 7937 SCCP phone, it shows the directory list for a fraction and shows XML Error 4. CUCM version is 8.5.1. Phone load is apps37sccp.1-4-4-0. Could someone help me.Karthik
Hello all,I am installing a new 2 xUCS-C220 server CISCO BE6K-ST-BDL-K9. When trying to build the Call Manager BE6K side.After deploying the OVA and trying to install the Virtual Machine in ESXi I get the following:Products not supported on this plat...
HiWe have connected CUCM with Avayia via Qsig Call Flow:CUCM--H323 VG-QSIG ---AVAYAEverything working ok but i am wondering if we can do the below scenarioWe move some extensions from Avayia to CUCM and we need these extensions for outgoing calls ...
Hello,Do we have a procedure document for replacing MCS7945 I3 server from the existinf CUCM cluster with a new server and adding it back to the cluster.Please share any doc if you have one.Thanks in advance..Regards,Sargam Patne
Hi guys,I have a problem with the Busy Trigger option on the CM (8.6.2).The phones have 2 Lines. on the first line there's:Maximum Number of Calls: 2Busy Trigger: 1ont he second line which is a shared line:Maximum Number of Calls: 5Busy Trigger: 2If ...
Hi all,I'm trying to install a SIP firmware (SIP894x.9-2-2-0) on a Cisco 8945 Phone.The is connected on a CME 9.1 and SCCP is working fine.THe "debug tftp events" show no error, but the phones still keeps the SCCP image.Here the config:voice register...
Hi again cisco techs.Have been scouring google re the above and getting mixed answers dependant on the search criteria used each timeEach 79xx phone will use SCCP firmware via I suspect cme 4.1 (unless told otherwise) to connect upWhat is the softwar...
hello,i did a reset factory to the cisco ip phone 7911 but it can't load the default firmware it shows only cisco. how can i resolve this problem?
Subject | Author | Posted |
05-21-2025 07:42 AM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM |
User | Count |
5 | |
4 | |
2 | |
2 | |
1 |
