Hiwhat is the difference between call manger 7 and call manger 8.6 and call manger 9
Dears,I have a 2 No's of voice gateway configured and i have only 1 No's E1 PRI connection to ITSP because cost of cutting solution,whenever the VG-PRI fails i will shift the E1 PRI to VG-SEC manually, I want to validate my design in the attached by ...
Hi all,I have a Cisco 2901 configured with an E1 PRI and connected to a Siemens hipath 4000 version 2. Incoming calls from the Siemens are delayed in call proceeding about 15 seconds. The Cisco configuration is:isdn switch-type primary-qsigisdn voice...
Hi, I am trying to use Bulk Edit to change a few settings in a bunch of subscribers at the same time. Some of the setting I want to change are: Greeting options - Send caller to - Repromt the user after this... - Number of times to repromtCaller...
Hello there,I have a 2800 that is log on CF space, I have ordered another one, but in the mean time I had a 2 gb USB that i inserted.. The usb was recognized by the router and all the CME files are there..My question is would it be possible to run al...
The scenario is as below:PSTN user calls local call centre number. Call hits the PSTN GW and then CUCM. CUCM forwards it to CUC Call handler where the welcome prompt is configured with menu. After pressing menu option call is forwarded t...
Hallo,für einen Kunden von uns haben wir auf der UC520 die Auswertung der Callstatistiken für eine ephone-hunt aktiviert. Leider funktioniert diese Auswertung nicht richtig. Alle "Abandoned Calls" werden leider nicht angezeigt, obwohl definitiv welch...
Hi AllMy conference phone cisco SCCP 7937G. my cme cisco 2921 router. the 12 PSTN line connected to fxo port. Please see the my configuration any more additional configuration in router ?please chek my configuration and update fast.voice-card 0 dspf...
Good morning, From two days I'have the following problem.I've two uc540 ( one in milan one in switzerland) connected between a internet tunnel.the milan extension are 10x, 11x and 12x and the Switzerland extension are 16x.All work well except this i...
Hi all,i am in critical state , now that i have to provide the customer a workable solution as to display names to the pstn number as the telco do not support it.cucm 8.5sip pstn servicecube voice gatewaythanks
Hi All I need your help in setting up configuring the ATA 187 on gateway 2911 router for fax services.configure the router SIP Customer IP address= 172.22.21.2570/30STC IP Address = 172.22.21.232/30Protocol= SIPSIP Port = 5060Transport ...
I have 3845 router which is loosing time and goes back to 1970 after reboot. All config remains intact only time is lost. How to fix this ???
Hi All,I am facing issue with voicemail ports. Few voicemail ports are showing status as Unregistered where some voicemail ports are registerd. When checked in RTMT Status Reason shows message "DirectoryNumberMismatch". What can be the issue ?I am us...
Hi,I have one question. All the IP phones are registered to Central CUCM. Can I know how customer use cue(voice mail) in remote site SRST ? IP phones ---------------- poe Switches ----------- SRST (cue) --------------------- CE router ===============...
We have our system where if somoene calls in it goes to one number but after X amount of rings it rolls over to another extension. How do I either change that to another extension or add a 3rd extesnion that after 1 ring there it rolls over to a thir...
| Subject | Author | Posted |
| 10-17-2025 09:01 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 6 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
