We are usning analog phones and connected to the VG224 router and when we dial from one analog phone and cannot see the extension number .All other phones are working fine.What will be the reason?There call manager is using..Please reply
This is a strange fault/bug I would like to know if anyone has experineced the same issue. I will try to explain,If the line description on a 7945 is over a certain number of lower case characters and contains characters with desc...
Hello, everybody!I have 2901 with PVDM3. Does I need to configure dspfarm and its profiles to use dsp resources on the same router?please help
Hello Sirs,I need to debug T30 messages in VG224, in both sides of this architecture:FAX -- VG224 -- MGCP -- CUCM -- CISCO 2911 -- PRI -- PSTN -- SIP TRUNK -- CUCM -- MGCP -- VG224 -- FAXI use the command "debug fax relay t30 all-level-1" and I do no...
Hi,I want a list of DN with their individual voicemail profile how can I get this in excel sheet?
Hi,i registered Polycom soundpoint 331 & two X-lite's with CUCM 8.0 using SIP protocol. i am able to cal from X-lite to polycom but unable to call from polycom to X-lite. two X-late's are communicating properly. there is proper communication between...
Hi All - Please help me to understand difference between controller, VoicePort and Interface and which layer it's working?Let's say call reaches Gateway , and we have controller 0/0/0 and Voice-Port 0/0/0 and Interface 0/0/0:15 How the signalling wou...
Hi all,We currently have CUCM 8.6 and Verint impact 360 V10 for call recording set and working...Is there any doco's for the integration of the two?The reason I ask is we are trying the recording solution via Extension Mobility by associating the "De...
Attempting to Update the Calling Search Space using either a Query or Custom File.The job appears in Job scheduler as "InComplete"Clicking Start Processing or Stop Processing produces the following error -Access to the requested resource has been den...
Hi all,I am using 6 x IP Phones 7960G's in SIP mode, using a Kerio Operator Server.When a user dials out from any of the phones, they seem to auto-dial too quickly. For instance if the user types the first few numbers of the telephone number they wis...
Hey Everyone, I grabbed an MP3 I wanted to use as a Ringtone and converated that to RAW with Audacity. I then modified ringlist.xml , uploaded it to the TFTP servers and restarted the service. Everything shows up and I can select that ringtone but it...
We have an extension that is attached to an analog line and is used to page throughout the building. The extension is one that we set-up in directory numbers but it is not part of our dial plan from the PSTN. It works fine as an internal extens...
Hi,today i got aware of Bug-ID CSCth87452 with the above Title. Does anybody know if this bug is fixed in CUCM/CUC Version 9.1.1(a)? The Fixed-In INformation tells about some 8.X and 1.0.X Version, but nothing about 9.X Versions.Any help is welcome!/...
Hi All We got two branches:Site A is registered to CUCM 8.0.2 on HQ and have HW-CFB on site.Site B is registered to CUCM 7.1.2 onsite and have HW-CFB as well.We have an ICT (Non-Gatekeeper Controlled) between CUCMs.When phone 1-A calls to phone 2-A w...
Hi GuysI´m trying to perform a recovery of a CUPS using the backup data but in the restore history the result is error. How to know problem detail?TIACristian
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM |
