IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1179 Views
  • 6 replies
Resolved! CUCM License
Hi,I'm installing CUCM on UCS server B200 I have already installed CUCM and i want to upload a  License which can be asked from cisco by PAK , For CUCM License after entering PAK when i move to step 2 as per the attached what i have to input details ...
Assume that the PRI is reporting the main BTN on outbond calls from within the Enterprise.  YOu want to have your DID number displayed when you make a call.  Where in CUCM do you set this up? In another example, an H323 Gateway with analog lines clea...
DrVoIP by Beginner
  • 2112 Views
  • 4 replies
When I access //X.X.X.X/ccmadmin, I can change my phone button layout (Example: button 3: Sam-100 , button 4: John-101, and etc).  When I access //X.X.X.X/ccmuser I do not have the phone button open layout.  I am able to access ccmadmin and ccmuser u...
tcvo91732 by Beginner
  • 487 Views
  • 3 replies
