IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5649 Views
  • 14 replies
                   We have a new Cisco CME 9.1 in one of our international offices that's displaying the incorrect time on the 9951 phone sets. I went to telephony-servcies>time-zone +240 but the time on the display did not readjust even after restar...
When we migrated out of version 6.x to 8.6, dial tone behavior changed.  Prior to the migration, there was no secondary dial tone.  After the migration, secondary dial tone occured after you dialed a 9 for an outside line.  So, [press speaker button]...
slade by Level 1
  • 545 Views
  • 4 replies
Hi all,I have been trying to make SIP calls from my Cisco 5300 RTR terminate to my ISP ( TATA) but still can’t get it to work call are getting disconnected after first Ring. Below are the equipment Involve.                                  E0        ...
HiI am facing issue of incoming call is landing on gateway, but its not going to cisco ip phone in Sip srst mode.Show Running deb isdn q931sh voice regist   t allBuilding configuration...Current configuration : 3405 bytes!! Last configuration change ...
Throwing this out here in case someone has come across this particular issue one of my sites is experiencing.Had 3-4 reports over the past days of phones, that after a call will not hang up.  Only a blank grey window shows on the display.  Using the ...
