IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5819 Views
  • 14 replies
Considering the figure below, my question is: Is it possible to filter a few number of calls to CUCM and bypass all others to PBX  E1 0/1/0 ?dial-peer voice 25295029 POTSdescription inbound call for phone 25295029incoming called-number 25295029destin...
Hello,In our environment we have two subscriber servers connected to two different core switches. Every subscriber server is dual NIC and we have performed teaming on them such that one NIC is connected to one core switch and other NIC to other core ...
Virstra001 by Level 1
  • 1237 Views
  • 10 replies
Hi All,Currently using a cisco router as my SIP GW.  My hope is to use this router as my sip trunk to my provider.  When i call the number assigned to the gw im getting the following two entries in the debug. //12/0E601AFD8035/SIP/Error/sipSPI_ipip_c...
rbblue234 by Level 1
  • 1427 Views
  • 14 replies
HiI have an issue with call volume on 3905 being extremely low. Is there any way of increasing the volume of the handsets beside the volume up and down keys on the phone. All the phone volumes are at maximum but the volume is very low. We using CUCM ...
I am currently CCNA certified and am working on voice with the view to taking certification this year. I have setup a test CUCME 7.1 environment with a mixture of 7900 series phones. The system is based on a 2821 router with aim-cue. I have a working...
msrhedges by Level 1
  • 410 Views
  • 3 replies
CUWL PRO includes WebEx Meeting Centre in the options available. Does this mean you can launch a WebEx session directly from your Cisco Jabber for Windows? OR it simply means you get access to a WebEx account that is not in anyway linked to the UC sy...
