HII have a problem , for CUCM back up . Firstly CUCM Back up page blank i can not add new . Other issue the SFTP server i need SFTP free server.Thank you
Hello,We have a problem about csim start command when we use ssh on our ccme router. Our company has an IT auditing so we need a proof document about happening problem (espacially troubleshooting) by using ssh in Cisco.com . We ha...
We currently have a UC560 and have recently added a new DID but when we receive an incomming call on this dialplan it displays the last two digits on the callerid as two dots(..). I have not been able to determine why the number is getting truncated ...
Hey Guys,would like your help because i would like to check why i'm receiving this error.When i try to place a call over a gateway that has a fractional E1 (10 channels only) i'm receiving the following output on "debug vpm signal".Apr 8 19:06:36 UT...
hi there,firstly i apologise for my bad English.i have a 2611XM router with 4 PORT Voice PM for C2600 Port adapter with 2 FXO slots and 2 FXS slots.firstly i want to attach a regular telephone to FXS port and redirect to a sip server. secondly i want...
Hi,I got a steal-knife in my wing-pipe with subjected problem, after wild internet browsing I couldn't anything which says you can carry an anlog Rada data on internet, I hope this plateform can help with that.SCENARIO:I have a customer who has two s...
What is the signalling between the CUPS server and the CUPS client also whats the signalling between the CUPS server and the CUCM.What signalling port number is it using?
Hi Expert/Masters, I am trying to upgrade unity connection form 8.5 to 9.1 it keep failing.I installed refresh upgrade COP file and regular upgrade process and it keep failing.Please assist me where i am going wrong so i ...
Hi all,our customer receive a notification on her Subscriber. Regenerate the Callmanager the certificate automatically or I have to generate these?CTL-Client is not in use!certmgr@LF101SW0245Certificate expiration Notification: Certif...
We have some VG204s and VG202s at remote sites and it would be useful to know if anything is plugged into the analogue ports in the device. Is there a command I can use on the device to check this out?thanksPaul
Hello all,I have a remote gateway with a single PRI that can receive calls just fine, but has never been able to place one successfully.The error I get is 0x80B2 - Requested facility not subscribedI have had a service call with the telco and after pl...
Team,I have a customer with following requirements. Can BE6000 solution serve this?1. Customer has 36 users total. 2. 10 of the users are sales users. Company wants to record all the calls coming to sales line.3. They want Sales supervisors to monito...
Hello allSorry but I need some clarification of the Premium numbers in Hong Kong so I can block them on our CUCM. I think I have the correct national and free services but getting confused on the latest Premium.......any one comple...
Hello all,I have a problem with the ringback on a sip-trunk to a SP.We have a UCM6.1 with a h323 gateway configured. This h323 gateway is also the CUBE and is connected to the SP. Everything is working only the ringback.Here is the voicegateway confi...
Hello Team,What is the differents between UCM 7825 node and IME 7825 node in BOQ it is an license or server.please check Thnaks & Regards
| Subject | Author | Posted |
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 4 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
