IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5408 Views
  • 14 replies
I am using Cisco UCM 7.1 ahd 7945 phones.  Is it possible to have the phone change its extensions by a user logging into the phone itself?  The issue is that people with different roles sit at a workstation through out the day.  Shift 1 might need di...
mmedwid by Level 3
  • 202 Views
  • 1 replies
Resolved! ELM 9.1.1 issue
Running new install - CUCM 9.1.1Enterprise LM issue: just installed a CUWL license.  Under Monitoring>License Usage - I am not seeing my UCM licensing componentUnder License Management>Licenses - I see the licenses fufilled including the UCM componen...
johnhsnow by Level 1
  • 953 Views
  • 6 replies
I'm trying to figure out why a simple site setup won't route or progress call's correctly.  This is an issue I've never experienced before so I'm a bit stumped as to why it's not working.  I feel as if I've debugged everything I can but can't see the...
                   Hello guys!     I need to configure names in Spanish on phones display that contain characters like ñ. Does the locale for Spanish (in my case, cm-locale-es_CO-8.6.2.1000-1.cop.sgn) will allow Spanish special characters to be confi...
fuhrersk8 by Level 3
  • 595 Views
  • 5 replies
I have UCCX 8.0.2.11005-20  and CUCM 8.0.3.20000-2 running on ESXI 4.1. bottom line is the uccx engine service would not start. If I restart the server I see manager manager go into inservice status and subsystem manager to partial service and that i...
Hi Everyone,It has come to my attention that when it comes to getting reports and queries its much better to use the cucm sql database, What I'm trying to accomplish:1. Gather All phones IP using (run sql select) command soo I can append other info l...
