IP Telephony and Phones
Labels
External calls are not redirected correctly
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 87 Views
  • 1 replies
ISR4351 Build
I am in need to replace my Cisco 2821 router and called a vendor. I informed the vendor that the router has to have the ability to connect our PRI line for voice. Well I received a router with only 1 NIM-1CE1T1-PRI card. When I tried to configure the...
Resolved! BE6M-M5-K9
DearsHow i would recognize it is BE6M-M5-K9 or BE6H-M5-K9, By entering CIMC i will come to know by HDD and RAM becz BE6H is higher is specs and for more than 1000 users. By without CIMC how can i know, is there any other way. thanks
adamgibs7 by Frequent Contributor
  • 693 Views
  • 1 replies
using CIPC
Hi;I see everywhere that Jabber is used on the lab but as you know making the jabber work needs intermediate/advanced knowledge of installing & configuring IM&P, which is not the case for someone who just started to learn the collaboration. I want to...
Speed dial limiting entries.
Having an issue with some users attempting to setup Speed dialing on Cisco 8841 Phones. The Directory is being limiting to the number is spaces left on the screen. If they try to access speed dials they entered (Pressing down on round button on the p...
JA1234 by Beginner
  • 223 Views
  • 2 replies
