Hello, Is there is a way to update / modify in bulk the Description, Alerting Name and ASCII Alerting Name of many directory numbers?
Is it or will it be possible to run Cisco ip communicator on a Mac M1 using Parallels/Win 11
I have a common problem with my cisco jabber but I can't find any solution In the community so I started to ask when trying to login to the jabber pc I get Your username or password is not correct this problem affects just two candidates in my corpor...
Hi,so we have a switchboard in production and the DN is getting forwarded to CUCA call handler. There is a scheduled forwarding working at the moment i.e transfer the calls to 1234 at 6.30pm etc. I am unable to figure out how this is set up. I am una...
cisco IP phone cp-7811 not getting DHCP ip address in one Catalyst 9200 switch the same phone can get IP with other 9200 switchesI have been checked everything correctly configured!interface GigabitEthernet1/0/3switchport access vlan 998switchport mo...
Hi, A tac engineer recently asked me to provide access to a DX650 via http from a pc. How do I do this? Thanks
A 4331 gateway was sent by Cisco to replace one that had a timing issue. The FXO card was swapped over to the new one but there are no voice commands in the IOS to configure it even through the router recognizes the card. I put the "old" IOS on the ...
hihi, I'm new.I have a problem with a CISCO 7811 no CUCM phone. Yesterday I updated the firmware to the "sip78xx.12-0-1-11" version because with the previous version when I connected via WEB I could not modify any data.After loading this firmware, ho...
I called Safeway in the U.S. today, and their initial hold music was familiar, but not Opus 1. Then when an agent put me on hold again, it was Opus 1. So it seemed to be Cisco telephony, but a different track. Is there a track list available somewher...
I have 1 remote office running on an MPLS at 30MBPS connection speed. This past week out of the blue the phone have started to randomly miss keep alive TCP packets, and failover/re-register. Nothing has changed at this location for the network, no ne...
When we do a TDR test on a cisco phone we are getting C and D as open. When we plug in a different device we get normal on all pairs. Do TDR tests work on cisco phones?
Have new Cisco CP-8861 phones. I would like to update the firmware so that I can set them up with our VOIP service. Unfortunately in their current form I can't seem to access a web GUI and I have been unable to setup a tftp server with an xml config ...
hi I have FXS interfaces to which analog phones are connected, I would like to configure the FXS to be able to give the time to analog phones automatically. thank you.
After configuring sip trunk my cp 9971 sip phones won't register with the error below: Jan 10 12:23:45.420: //33/FD5F39A5801D/SIP/Msg/ccsipDisplayMsg:Sent:SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 172.16.90.137:5060;branch=z9hG4bK6a527bfcFrom: <sip:10...
Dear All, I have a unique issue, where if agent received call through UCCX, call log is not appear in phone directories. But, if direct call from user to agent extension, call log is appear in phone directories.note: agent using CP-7960G When an agen...
Subject | Author | Posted |
05-24-2025 08:05 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-22-2025 08:53 PM | ||
05-21-2025 06:23 AM |
User | Count |
5 | |
4 | |
2 | |
2 | |
1 |
