IP Telephony and Phones
watch here Journey banner_2
Labels
Hello,I have a couple of Cisco 7961G phones that when power is applied, all the lights light up but nothing else happens.  I'm talking about the lights above the switchhook, all the line buttons and the 3 including the speaker button. I have tried to...
awright by Level 1
  • 518 Views
  • 2 replies
What is the best facility to use to accomplish the following:(a) determind which Gateway a call used to enter or exit the enterprise?(b) Is it possible to see the real time activity of calls on a gateway in a fomrat other than debug?Thanks           ...
DrVoIP by Level 1
  • 497 Views
  • 1 replies
       I am having a strange problem where a user cannot call one specific number (from different phones).  The dialed number will ring once, then you get a "your call cannot be completed as dialed, please check the number and try your call again".  ...
cowanp by Level 1
  • 5039 Views
  • 2 replies
Currently, when someone calls our hunt pilot number (9000) it will attempt to ring a member phone 3 times before it logs that phone out of the hunt group, I have two questions relating to this:1) Is there a way to increase the number of rings each hu...
jmartin by Level 1
  • 806 Views
  • 1 replies
I have CUCM 9.1 and a standalone ELM server on the same UCS box.  I migrated the licenses and everthing was running and licensed.  I did a DRS backup of ELM and shutdown the server on UCS1.  I built a fresh copy of ELM with the same IP, hostname, etc...
