Hi I need to configure BLF Call Pickup for Cisco 9971, Can you please share the Steps to configure BLF Pickup for 9971 ?Regds$
Dearsi have a problem with FXO Port installed in H323 gateway. the problem is when the incoming call reaches to the FXO port, connection plar command configured to deliver the call to a specific extenion but the problem is the caller hearing the ring...
Hi All,hope someone can help us with this strange issue, in one of our locations the hold, transfer and conferece button are not working, we get the following error message: that key is not active here.We have this problem only with external cal...
I am configuring one way intercom(manager to assistant) in CUCM 6.0 and it is not working giving busy tone when manager press the speed dial of the assistant .here i have some questions?our DID begin from 600 to 899 do i need to use one of the DID a...
Hi all, i have 4 7940 phones with ext. 1001,1002,1003,1004. I have 4 FXO lines. Now my scenario is simple so pls guide me. I want phone with extenstion 1001 when he press 9 he should always get FXO line 1. When another guy with extension 1002 press 9...
Hi,I have a 2901 router and I want to use it as a CME. Is it posssible to use only an IOS supporting a CME or I must purchase a license for 2901 router to support UC features ?Any help will be appreciated !Many thanks
Dear All,I have CUCM.8.6 i am planing for upgrade CUCM 9.0 Could you please help me harware and system requirement and Licencing requirements i am waiting for valuble replay RegardsMuhammed Shafi
Hi Team,I have done the configuration to create CDR file as given below and I am receving the files in FTP server.. But as per our 3rd party vendor the file is not giving the rigt information like main line number and data is not in...
Anybody here used the Verint Impact 360 for recording IP phones? The Verint reseller was asking details regarding Peripheral ID, upon checking the net the peripheral ID us used in UCCE. Any idea on how to integrate or use Verint Impact 360 for record...
Hi All,I would like to know if it is possible to Take a report of Extensions on the basis of Usage.I would like to get the DNs and which has no usage in the last 30 days.. Is it possible to retrive this kind of information from CDR.Appreciate you hel...
Hi all,Does anyone find where can we configure the default Line CSS for Auto-Registered devices?I Explain : We use Line/Device CSS design.Device-CSS allow all calls, and bocked call are processed on the Line CSS.We need that all phones can register i...
Hi,i have configured the Autoattendent in cisco unity, its working fine but one small problem we are facing iswhen any one dials the main number from outside the auto attendent greeting is playing and when the caller dials 0 or any other extension th...
Hi All,Is there any way to adjust the interdigit timeout globaly?I am using AA script in the router. the customer uses 0 as an access code. all outgoing pots dial-peers start with 0. if someone call the AA and press 0 to transfer the call to operato...
Hello,I have a customer running Unity connection on UCS-B200. Client tried to do the upgrade from 8.0.3 to 9.1.1 which has been done successfully. Client noticed that the upgrade was very slow. They changed the VNIC from flexible to 1000 and the upg...
Hi all,am having cisco 2921 with PVDM3-32U64, 2 fxo, 1 fxs and 1 E1 cards. Meet me conferece can`t be initiated. it shows in the phone cannot complete conference It allow me to do maximum session 1 for conferece and max session 5 for transcoding. the...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM |
| User | Count |
| 5 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
